ACTUAL inj. flowrate
Old Jan 29, 2008 | 01:55 PM
Slewis's Avatar
Car: anything capable
Engine: varies
Transmission: both
Axle/Gears: wish it was CV.
Due to all the inconsistant responses to my Q's about FlowRates, I was thinking about testing my injectors myself and was wondering if my approach would be the right way to go about it. I'm thinking about running the fuel into a beaker, while simultaneously measuring the STATIC timeframe, then doing the math to get my gm's/sec.
Also, if this does give true MAX flowrate is this the figure that is used as the injector constant in the OD.bin ?
Old Jan 29, 2008 | 04:09 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: ACTUAL inj. flowrate
Nothing wrong with doing it that way. A good scale will be more accurate then the volume as its done in mass/time.
Old Jan 29, 2008 | 04:51 PM
Slewis's Avatar
Engine: varies
Transmission: both
Good point, think my a/c scale is perfect for the task. Now to find a decent beaker........
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
FormulasOnly
Oct 2, 2015 05:52 PM
dusterbd
Sep 29, 2015 08:40 AM
