L03 Heads and throttle body
Old Feb 4, 2008 | 02:06 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
What are the best heads to get? Does the throttle body need to be replaced? I plan on having around 260-280hp and like 390lbs of torque. Im going to get the Edelbrock intake manifold, and an LT1 or LT4 cam.
Old Feb 4, 2008 | 02:22 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: L03 Heads and throttle body
idk about the heads but the throttle body can deffinately support the power if you know how to burn chips for your ecm. If you can't burn chips then you might as well learn or go carbureted cause if you don't burn a chip then it will never run right.(i would recommend learning to burn cause you can keep your drivability and gas milage).
Old Feb 4, 2008 | 04:05 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
You're probably going to get a bunch of recomendations to use Vortec heads off of a 350 (L31). I would listen to those recomendations. You can get a set from Summit or Jegs brand new for around $500.00 assembled. They will lower your compression ratio due to have a larger CC. You can mill them down and use a thin head gasket to compensate.
Old Feb 4, 2008 | 04:28 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Im going to get the EBL after I get the new intake manifold. So when I get that im going to def need some help setting it up for the first time.
So get them and take them to a performance shop, what should I tell them I want, exactly? I guess I will just have a shop install them and mill them down and everything.
Old Feb 8, 2008 | 05:17 PM
Pontiacguy18's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.42 posi
ok dumb question and I feel embarassed asking, but I have a 305 and want to bore my cylinders to create a little more power with oversized pistons... do I need special heads if I bore it .040
Old Feb 10, 2008 | 07:47 PM
ljnowell's Avatar
you probably wont make it .040 on a 305. Either way, the gain would be minimal. Boring is a maintenance act, not a power increaser.
Old Feb 10, 2008 | 08:14 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Yeah, if you want more cubic inches, you really need a bigger stroke rotating assy.
And to the smart people, how do the vortec heads compare to the LB9 TPI heads? I thought I heard that you can put TPI heads on a LO3 and get some easy gains too?
Old Feb 10, 2008 | 10:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The ones that claim the "Great Gains" from stock 081 heads on a L03 are on crack. I have seen a ported pair of 081s not gain the upper hand on a cammed up L03 until after 4,300 rpm.
Next to ported ZZ4 heads, the 059 casting Vortec 305 heads are the BEST GM heads you can put on a 305.
Old Feb 10, 2008 | 11:16 PM
Engine: LO3
Well, I figured the vortec heads would give better gains then the TPI heads, but I didnt figure it would be that big. I still am undecided on what I want to do in the long run. The main thing, is, the car is my daily driver, and will be for a long time. Another car is out of the option.
So whatever I do to this car, it needs to be easy enough to tune in an afternoon (for a noob), needs to get some decent gains, hopefully I could see 200HP, maybe like 280TQ, and needs to retain my current gas milage.
evilstuie
Jan 9, 2020 08:29 PM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
