Need Help on 305 TBI to 350 TBI Swap
Old Apr 27, 2008 | 05:31 AM
Firefighter's Avatar
Car: Trans Am
Engine: 355 TBI
Transmission: Automatic
Axle/Gears: 9 Bolt 3:27 Gear
Hi Guys,
I done the 305 to 350 TBI Swap and now I have a Problem. Everything is hooked up correctly and all the Parts are new.
I have Spark, the Fuel Pump is Priming but the Injectors wont Spray!
I got an 8746 ECM from a Caprice and the Chip that was in there is one from ADS.
Could that be that the Vats System is activated? I have no VATS on my Car?
Or is the Spark Modul in the Distrubtor not sending a Signal to the ECM so that it knows that it should pulse the Injectors?
I´m Stuck on this, please help!!!!
Thanks so far!
Old Apr 27, 2008 | 08:05 AM
DM91RS's Avatar
Car: 91 RS
Re: Need Help on 305 TBI to 350 TBI Swap
What ecu was in the car to begin with?
Old Apr 27, 2008 | 10:00 AM
Car: Trans Am
Engine: 355 TBI
If it is the Computer what you mean, it was the 8063 and I swaped it to the 8746.
Or what do you mean with ECU?
Old Apr 27, 2008 | 10:27 AM
DM91RS's Avatar
Car: 91 RS
yes.
Is the car trying to start as in the engine turning over with the starter?
Old Apr 27, 2008 | 10:38 AM
Car: Trans Am
Engine: 355 TBI
Yes the Engine is Turning and the Starter does his Job, everything sounds normal. Could that ESC be bad and thats why the ECM doesn´t give the Pulse for the Injectors?
Old Apr 27, 2008 | 10:48 AM
DM91RS's Avatar
Car: 91 RS
I'm not the one that can answer that question. Do you have a service manual?
Old May 3, 2008 | 03:27 AM
Car: Trans Am
Engine: 355 TBI
Found the Error, the VATS was activated in the Chip!!
Old May 3, 2008 | 10:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I didn't think that Caprice's used VATS. That may be how you ended up with the ECM & chip, it wouldn't run in the Caprice either. VATs on the Camaro & Firebird TBI cars started in '89.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
dutch930
Sep 11, 2015 06:58 AM
st.evel07
Aug 13, 2015 06:15 PM
