Cleaning up the engine bay.
Old May 7, 2008 | 09:33 PM
89'CamaroRS's Avatar
Car: 1989 Camaro RS
Engine: Carb'd 350ci
Axle/Gears: 3.08 limited slip
Well I just bought a Camaro. Its an 89' Rally Sport with a TBI 305. Under the hood it looks like theres alot of crap I dont need. Looks really cluttered. My question is, what can I get rid of and what do I need to keep? Im probably going to throw a carb on, also.
Old May 7, 2008 | 09:40 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Cleaning up the engine bay.
get rid of the manifolrds and run headers, that will help unclutter the engine bay by getting rid of all the smog lines, get rid of the a/c as well if it has it. Then the smog pump. all that will really help make the engine look better. Also an open element helps by getting rid of the stock intake.
Old May 8, 2008 | 01:18 AM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
I agree with everything he said and all, but i think if you keep the smog pump on it will look beeter imo, but it just what you like.
Old May 8, 2008 | 03:51 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Just replace the smog pump with the smog delete pulley.....
Old May 8, 2008 | 07:07 PM
Engine: Tbi 305
Axle/Gears: 3:73s
Yea true thats what my dad has on his Gmc looks pretty good. Is there any way to remove the ac and replace it with a pully?
Old May 8, 2008 | 09:12 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
yup. 1LE package contained both the smog and ac deletes.
Old May 8, 2008 | 10:36 PM
oldred95's Avatar
You guys must be dang tough if you're willing to remove the AC just because it looks better. Get ride of the smog crap and really you could get rid of the EVAP canister and purge solenoid because its just about useless on OBDI. It may not even set a code when you take it off its that useless.
Old May 8, 2008 | 10:41 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
not only does it look better without a/c it also frees up a microscopic amount of horsepower. but every little bit helps.
Infested
May 22, 2018 11:56 PM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
