Poor L05
Old Jun 16, 2008 | 10:34 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Poor L05
i did an engine swap over the winter and i have been messing with the motor ever since.... for one when the rpms reach somewhere in the 4500-5000 range the car starts to run like **** and looses power and falls flat on its face until it shifts... i have adjusted the timing and i set it at zero and it runs sluggish compared to advanced timing, with the timing advanced it seems to idle ALOT smoother but misfired alot when it is advanced enough, i was in the engine bay listening to the motor and i advanced the timing off that gauge thing and seems like it idled good there (with the exception of the misfires) but no matter what i do it still seems to run crappy up top... and another thing i have been timing my 0-60 runs and they are in the range of 8-9 secs... (thats not much faster than my L03 completely stock was) i did one a long time ago it was around a late 7 sec run but since then i have been slow... could it be because of my gears? plus i just did the ultimate tbi mods and i feel no difference at all... doesn't make the car differ form how it was at all... any ideas guys? I'm getting frustrated....
Old Jun 16, 2008 | 10:59 PM
1988-305-tbi's Avatar
Re: Poor L05
checklist: 350 prom chip/ 350 esc module/ 350 injectors
egr valve hooked up/ vacum lines?
does it pop and backfire alot?
Old Jun 16, 2008 | 11:40 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
it does pop sometimes when its up high in the rpms... up to 4500 its fine.... it has the Blazer Computer in it, along with the 350 injectors... egr valve should be hooked up fine...vacuum lines are ok i think,
Old Jun 18, 2008 | 03:15 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
I did the o2 sensor tuning thing... it read between .87-.9 and when it started running crappy it would either read .90 or .91 and one time i got a .92 too.
Old Jun 20, 2008 | 04:28 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
I got it so it doesn't do the dieing thing anymore but i'm getting 9-10 sec 0-60s.... very dissappointed with this motor if thats all it can do with ultimate TBI mods, headers, exhaust, and open element. Anyone have any idea? and i messed with fuel pressure alot and the timing and nothing changes anything......
Old Jun 20, 2008 | 08:05 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
anyone?
Old Jun 20, 2008 | 08:07 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: Poor L05
if you play with the throttle at the throttle body, try snapping it open quicky and see what happens, see if it hesitates, if the fuel pressure cuts out and or if it backfires, i had similar problems with mine but found out my timing was off and wouldnt hold because my cam walked.
Old Jun 20, 2008 | 08:19 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
i don't have a fuel pressure guage on it, but when i snap it open it would (for the first few times) would kinda sputter for a second then the motor ran for a min and it would just rev up after that.
Old Jun 21, 2008 | 12:52 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
I just ordered an ALDL cable and waiting for it, i'm trying to figure out how to use the programs and read the data so i know before i do it.
Old Jun 21, 2008 | 03:49 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Re: Poor L05
Do you have a check engine light on? Why did you swap in a Blazer computer? They aren't directly compatible, you can't just plug it in, maybe you know that, but just making sure you didn't do that. All your problems are in the chip.
Old Jun 21, 2008 | 11:20 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
how would it not plug right in? The tbi harnesses are the same... and its the blazer's motor with the blazer comp.. why wouldn't it work? its the whole 7747 ecm hooked up not just the chip...
Old Jun 22, 2008 | 12:27 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Poor L05
It will plug right up to the existing connectors and work fine, its just calibrated for the needs of a 6,000+ lbs truck not a 3,600 lbs car. The VATS, Powersteering Pressure switch, and IAT will no longer be functional while using the 7747 though.
Old Jun 22, 2008 | 01:01 AM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
i don't really have a choice..... its either that or the original 305 ECM..
Old Jun 23, 2008 | 06:59 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
What are your inputs on data-Logging software? What one do you guys use and which one is the best?
Old Jun 23, 2008 | 07:15 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Poor L05
I can think of a couple of reasons that you are having problems.
1st, the 700r4s in the TBI trucks were calibrated to upshift by 4,200 rpm or so. The injector pulsewidth is pretty much maxed out by about 4,000 rpm. Running much over the WOT Upshift RPM of a TBI truck will make the injectors run static.
2nd, the ignition control modules used in the cars and some trucks have a built-in spark latency change as the rpms increase. This was done purposely to limit the maximum rpm of the engine. What happens is as the engine runs over 4,300 rpm, the timing starts to retard until around 5,000 rpm it peaks around 9* retard from the latest entry in the spark table.
3rd the camshaft and valvetrain in your L05 unless upgraded were designed to run with the 4,300 rpm WOT upshift in mind. The cam was a very mild grind and the factory engineers wanted it to live a good long life. Being a hydraulic flat-tappet cam the engineers used valve springs better suited for childrens slinkys. The later model TBI trucks even had a 4,800 rpm fuel shut-off programmed into their PCMs.
Old Jun 23, 2008 | 07:18 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Poor L05
WinALDL
ScannerPro
- both should work well with 7747ECM.
A word of caution - NBO's are not very accurate at fuel mixtures away from 14.7:1. WBO is the next best thing to dial in WOT performance.
ECM comment
A stock 7747 can be equipped with EBL which can support extended RPM operation or convert to later PCM
//RF
Old Jun 23, 2008 | 09:21 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
Originally Posted by RFmaster
WinALDL
ScannerPro
ECM comment
//RF
i don't really understand anything of what you just said lol. whats an NBO, WBO and EBL?
Old Jun 23, 2008 | 10:26 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
That sounds like the exact problem... when the rpms get high it runs like crap and looses all power. How can i get around that? My next mods are cam and heads. I was gonna have my ECM "reflashed" by some guy where you send in your ECM and he reflashes them for $50. Then sends it back. Any ideas? and how hard is it to change a camshaft?
Old Jun 23, 2008 | 11:28 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: Poor L05
EBL is a computer system dynamicefi.com its what I run and find it to be excellent.
NBO is narrow band oxygen i think which would be the stock oxygen sensor.
WBO is wide band oxygen I think and that would be something from innovative motorsports, gives much more accurate air to fuel ratio readings then the stock NBO sensor.
Old Jun 23, 2008 | 11:36 PM
RFmaster's Avatar
Car: 75 Beast
Re: Poor L05
Thank you
Old Jun 23, 2008 | 11:43 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
thanks
Old Jun 24, 2008 | 12:29 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Poor L05
To fix the module problem is pretty simple, just grab a 369 marked module from a 5.0/5.7 TBI fullsize van. Rbob recently did some testing with the 369 and 048 marked modules. I had noticed a high rpm power drop-off when I installed my replacement module in my van. After reading this post, I went and grabbed a "369" module from a 1993 fullsize G20 Van. My power over 4,000 immediately increased.
048 and 369 modules
Here are the results of his testing.
Originally Posted by RBob
Have some interesting information to add this this thread.
First item to note is that in the opening post of this thread, the table shown as for AUJP is not. It is the latency table used for AXCN & ANHT. Which are Corvette large cap distributors. The poster in the thread that liquidH8 linked switched the two tables in his post.
AUJP uses table 2 in the following:
Code:
	Table 1	Table 2
RPM	 usec	 usec
6375	137.34	305.2
6000	137.34	305.2
5600	137.34	305.2
5200	137.34	305.2
4800	137.34	305.2
4400	152.6	305.2
4000	152.6	289.94
3600	137.34	320.46
3200	167.86	305.2
2800	183.12	244.16
2400	137.34	274.68
2000	137.34	244.16
1600	106.82	305.2
1200	45.78	274.68
 800	 0	213.64
 400	 0	  0
   0	 0	  0
I have been able to identify two different ignition modules for the small cap distributors. They are the 048 and the 369. Check out the picture of the modules. It is the first 3 digits.
I ran 2 each of the 048 & 369 along with a Holley module through some tests. This was done on a live engine using a marked balancer, timing light, and the What's Up Display to show the commanded SA timing and the engine RPM. The EBL Flash had 5 calibrations banks set up for testing.
Bank 0 was the stock calibration to start up the engine and let it settle in.
The other four banks all had the main & extended timing tables set to 20 BTDC. Temperature comp, PE, launch mode, and whatever else was zero'd out.
Then each of the four banks had different latency tables. Banks 1 & 2 had the two tables shown above. Then banks 3 & 4 had the same tables with the low RPM latency values of 0 filled in with the first value greater then 0 from above it.
Code:
Instead of this:
1600	106.82	305.2
1200	45.78	274.68
 800	 0	213.64
 400	 0	  0
   0	 0	  0
It was:
1600	106.82	305.2
1200	45.78	274.68
 800	45.78	213.64
 400	45.78	213.64
   0	45.78	213.64
The reason for this was that it was found that the at-crank timing dropped off with the stock table values of 0. The was still latency at the low RPM's that needed to be accounted for.
With this change running the RPM from 800 through 3200 had each module with the appropriate table holding a steady SA. Switch the table and the advance moved around as the RPM changed.
The Holley module (part # 891-103) matched table 2. This was from 800 through 3200 RPM. Did not test past this RPM.
You may be thinking that 3200 is a low RPM. However, look at the engines/vehicles the ignition modes are used in. None of these engines are high RPM. Trucks, Vans, TBI 3rd gens, Caprices, Wagons, even the TPI engines aren't high RPM engines. Note what happens in the following tests. . .
Another test: while checking the timing as the RPM was increased, both the 048 & 369 modules held steady until a particular RPM. This was with 048 & table 1, then 369 with table 2.
The 048 module, it held steady timing until about 3800 RPM where it retarded 4 degrees. Then by 5000 RPM the retard had increased to 6 degrees.
The 369 module, it held steady timing until about 3200 where it gained 2 degrees of advance. This held steady to 5000 RPM, which is the highest RPM it was checked at.
If we could get a sampling of the ignition module in various 3rd gen engines it would be helpful. Under the cap check the 3 digit number and post back. Along with whether it is TPI or TBI. If you know the stock BCC that too would be helpful.
Conjecture:
I know that the latest f-body TBI calibrations use table 2. This matches module 369. Same as the AUJP TPI calibration. I wonder if the 048 modules are for performance limiting, and are set up to limit the engine RPM. With the timing retarded, the power drops off, and most people either up-shift or lift.
Where the 369 modules (the ones I have are from 5.7l full size vans) are more performance oriented. What is interesting is that the 369 modules I have are newer then the 048's. Some even look to be replacements (too new for the age of the vehicle). Maybe a GM upgrade?
RBob.
A camshaft swap is fairly easy, but takes some mechanical knowledge and lots of time. Its not something that you would want to do in a single weekend.
I doubt that a mail order tune is going to help you any. You really need a larger camshaft, better valvesprings, and a non-mail order retune of the ECM.
Old Jun 24, 2008 | 12:34 AM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
Another question for cam experts out there. I am going to be going Vortec heads, i already have flowtech headers 2 1/2" y-pipe into 3" Flowmaster cat back. It will have the SUM-226018 intake with the Carb to TBI intake adapter. along with the ultimate TBI mods with open element and soon i will be going to 3.73's in the rear. Any idea on a cam cause thats my weak point. Thanks a lot!
(also if i picked bad parts let me know and i will probably change what i buy, also keep in mind I'm trying to save money) And all this will be on the L05(which is completely stock right now except for open element and headers and exhaust.)
048 and 369 modules
That thing is on the side of the distributor right? All i have to do it change it and my high rpm power should come back?
Last edited by v10viper04; Jun 24, 2008 at 12:38 AM. Reason: Automerged Doublepost
Old Jun 26, 2008 | 12:47 AM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
someones gotta know about camshafts here.......... I know there is someone here lol
Old Jun 26, 2008 | 01:31 PM
Ronny's Avatar
Re: Poor L05
Check out comp cams web site. locate computer controled cams. i assume the Blazer is hy flat tappet. You will see LSA's at 112-114 range. my first cam was 210/216 @ .05 113 LSA. small cam easier to tune.
Old Jul 6, 2008 | 02:13 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
Well i swapped out the Truck ECM for a buick roadmaster ECM and my top end power is back it pulls all the way to 5500 rpm, But to really gain the benefits from that particular ECM i have to get bigger injectors right? B/c the roadmaster L05 used bigger fuel injectors than the truck L05's right?
Old Jul 6, 2008 | 02:56 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
Right?
Old Jul 6, 2008 | 04:53 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: Poor L05
Probably not.
The RM LO5 was rated at 180 fwhp during 1991-1993; truck LO5 were at 195 or 210 fwhp (not sure). The trucks had a different (flat) tappet cam that was slightly warmer than the peanut cam used on the RM 350 (same peanut roller as used on 3rd gen Fcar 305), and a better exhaust, so they were rated higher and MAY have used something higher than 61 #/hr.
So IMO they either used the same (flow rating) injectors, or the trucks got slightly larger ones.
Old Jul 6, 2008 | 05:31 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: Poor L05
Well, HOT ROD just did an article about Comp Cams 5 best cams. Tested on Vortec 906 and AFR 195 Street Eliminators with an intake that should be pretty close to the one you've chosen.
Obviously these all did around 20-30 lb-ft and hp better with the higher flow of the AFR heads, but here are the Vortec numbers.
I went with the Xtreme Energy XE268H cam for my 327. Recommended and researched because it left enough vacuum for tuning with TBI.
Here's the list in no particular order on a 10:1 355.
1. XE268H-1- 372@5400 / 409@4000
2. Magnum 280H-10 377@5700 / 402@4100
3. XE274H-10 385@5600 / 413@4100
4. Magnum 292H-10 399@6000 / 406@4300
5. Thumpr 283THR-107 395@5900 / 417@4200
You would need to either buy the modified Vortecs for the lift of these cams, or else take them to a shop and have them modified.
Old Jul 6, 2008 | 06:13 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Poor L05
Originally Posted by kdrolt
Probably not.
Most of the Cadillac/Buick/Chevy Caprice 180 HP 350 engines that I have come across had 55# 305 injectors in the TBI.
Old Jul 7, 2008 | 08:36 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
i am still irritated, i feels like its running good but its still putting down upwards of 8 sec 0-60's, i just took a vid from 15mph -60mph and it takes 8 secs. thats terrible! Any ideas? I'm starting to want to just give up on it.
Old Jul 7, 2008 | 09:07 PM
DM91RS's Avatar
Car: 91 RS
Re: Poor L05
2.73's ?
Old Jul 7, 2008 | 10:50 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
i was told before that i should be getting 7-8 sec 0-60s with the setup i have right now, which i assumed was including the 2.73's.
Originally Posted by DM91RS
2.73's ?
Your L03 RS has 3.73's right and a T5? Whats your 0-60 time?
Old Jul 8, 2008 | 12:00 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Poor L05
When in doubt go back to the basics. The engine requires several things to run properly. Adequate compression, a good air/fuel mixture, and a properly timed spark. Partially deprive it of any of the preceding and the engine will still run, but will run poorly.
A.) Check the Compression
B.) Check the cylinder leakdown
C.) Check for proper valve action
D.) Check the ignition timing
E.) Ensure that you have 61# 350 injectors in the TBI unit
F.) Test the fuel pressure to make sure you have atleast 12 psi (Spec is 9-13)
G.) Measure the backpressure on the exhaust system during a WOT 2nd gear pull (should be less than 3 psi)
The cam in that engine is VERY small and does not respond well to minor bolt-ons. I mean the intake valve is only bumped off the seat .350" and the exhaust valve .385", it is also not at peak valve lift for any time and the ramps are not all that aggressive. A LT1 cam, a full exhaust, and a properly tuned ECM will wake this engine up incredibly. I ran a LT1 cammed L03 (added flat-top pistons) truck engine on the stock 1992 Van ECM in my van with the only other additions being headers and a 2 1/2" dual exhaust system. The van HAULED BUTT! Easily ran 0-60 in 8-9 seconds despite 3.08 gears and the stock 1,600 rpm torque converter.
http://youtube.com/watch?v=UEeZ5ruugWA
http://youtube.com/watch?v=PX5Av4pS1RA
This is a stock 4,200 lbs Buick roadmaster which uses something near a 2.56 gear. 0-60 in 9 seconds (12-3=9)
http://youtube.com/watch?v=1U7O-U4EF00
Old Jul 8, 2008 | 12:11 AM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
How do i do B,E,F,G? lol i'm not that technical.
Old Jul 8, 2008 | 02:40 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Poor L05
Well Fast, thanks to this thread I just diagnosed what was wrong with my truck, and possibly what's going on with my Camaro. Maybe that's why the ARAP bin has so much PE added at the top end?
Old Jul 8, 2008 | 02:55 PM
DM91RS's Avatar
Car: 91 RS
Re: Poor L05
I don't know but I'll bet with my one wheel peel it will spin forever if I tried. I'm working on a Torsen and a bit lower gears which might let me try soon. My engine has alot of miles and it's my DD so I don't beat it too hard anymore until I get a fresh short block in it....BUT it does pull strong for what it is IMO so it might not be too bad. I do remember that the same engine with the same mod's [full exhaust], but with a 2.73 and auto was a dog compared to the 5 spd/3.08. I hated the auto/2.73 combo. It was in an 89 RS.
Old Jul 8, 2008 | 05:47 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Poor L05
I don't know but I'll bet with my one wheel peal it will spin forever if I tried. I'm working on a Torsen and a bit lower gears which might let me try soon. My engine has alot of miles and it's my DD so I don't beat it too hard anymore until I get a fresh short block in it....BUT it does pull strong for what it is IMO so it might not be too bad. I do remember that the same engine with the same mod's [full exhaust], but with a 2.73 and auto was a dog compared to the 5 spd/3.08. I hated the auto/2.73 combo. It was in an 89 RS.
Do one run for me and time it, you don't have to redline it if you don't want to, i would just like an idea of your 0-60 time. Thanks
Old Jul 17, 2008 | 10:06 PM
Re: Poor L05
It's official, I popped the distributor cap off and there sat an 048 module. I pulled it and swapped in the 369 module from my S10 that I had accidently swapped for an 048 module a while back and the car wouldn't run. It finally started up but ran for a few minutes and died so I swapped in the old Holley Annihlator module that checked bad repeatedly and BAM started up and the top end power is back in my car! Get this, the car pulls harder now than it did before I started swapping modules, and I went from the ARAP bin down to a bone stock AJUP bin just to be safe!
Old Sep 13, 2008 | 06:57 PM
Re: Poor L05
*APYP not AUJP* oops.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
shanelique22
Sep 24, 2015 06:30 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
