oil pressure
Old Jun 25, 2008 | 05:05 PM
Flip66's Avatar
oil pressure
I am converting to TBI I noticed the computer has an oil pressure senor wire on it will the car run with out, can I by pass it or where do i connect it. I have the 1 wire sending unit in the car now.
Old Jun 25, 2008 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pressure
The computer doesn't have an oil pressure sensor.
Old Jun 25, 2008 | 11:15 PM
Flip66's Avatar
Re: oil pressure
sorry you are right its the Tan/Wht it looks like it goes to the output of the fuel pump relay is that correct
Old Jun 26, 2008 | 12:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: oil pressure
What year did your TBI harness come out of?
Old Jun 26, 2008 | 09:38 AM
Flip66's Avatar
Re: oil pressure
its out of an 89 chevy truck with a 350
Old Jun 26, 2008 | 07:55 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Re: oil pressure
the fuel pump isn't going to come on, and you can expect longer cranking periods.
Old Jun 26, 2008 | 09:19 PM
Flip66's Avatar
Re: oil pressure
what do I need to hook it too.
Old Jun 26, 2008 | 09:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: oil pressure
The fuel pump will turn on without the oil pressure switch. You wouldn't even know it was missing, unless your fuel pump relay died.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
