CAM??
Old Sep 3, 2008 | 01:43 PM
smoked's Avatar
CAM??
Will a cam that is out of carb'd motor work in a 305 TBI?? Also all the other valve train stuff work (valve springs, timming chain, roller rocker, ect)...Thanks Jeremy
Old Sep 3, 2008 | 01:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: CAM??
Yes, as long as it's a roller cam. Why would you want a used cam though?
Old Sep 3, 2008 | 02:08 PM
smoked's Avatar
Re: CAM??
Sorry, i didn't mean a used one. I meant are they compatible. Cause i found one in the summit catalog that i want, and i didnt know with it be carb'd or FI would make any difference. Will all the other valve train stuff work as well, like valve springs, timming chain, ect?? Thanks
Old Sep 3, 2008 | 02:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: CAM??
It'll depend on which cam it is then.
Old Sep 3, 2008 | 02:24 PM
smoked's Avatar
Re: CAM??
im looking at one out of summit.. its a 224/230 @50 with a both int/exh being under .550 lift??
Old Sep 3, 2008 | 02:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: CAM??
Which cam out of Summit?
Old Sep 3, 2008 | 02:38 PM
smoked's Avatar
Re: CAM??
The part number is CL12-242-2
Old Sep 3, 2008 | 03:05 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: CAM??
"Cam Style: Hydraulic flat tappet"
Pretty sure you can only use hydraulic roller rocker
Old Sep 3, 2008 | 04:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: CAM??
No, you can use a flat tappet cam in a roller block if you use the right timing chain, lifters and pushrods.
That cam isn't listed as computer-compatible, but it's pretty mild so it might work.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
