SMOKE SMOKE SMOKE
Old Dec 18, 2008 | 08:44 AM
hitmann91's Avatar
SMOKE SMOKE SMOKE
When i bought the car 2 years ago the exhaust fumes were clean, now my car smokes a hell of a lot when i start it/any acceleration. it has a 305 tbi with 166,000 miles on it, and flowmaster exhaust with the cayt removed. but the smoke just started about 6 months ago, does anyone have any ideas on how to fix/what is causing this, thanx
Old Dec 18, 2008 | 08:54 AM
goldens98's Avatar
Re: SMOKE SMOKE SMOKE
I had the same problem, it's your valve stem seals. They're worn and need to be replaced. It's a very common problem. When your car cranks it smokes and when you're at a red light and you hit the gas the smoke comes out and eventually burns out, but if it smokes all the time then it's your rings. Have you changed oil lately?
Old Dec 18, 2008 | 09:21 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Yes, sounds like valve stem seals.
Head job anyone...haha
Old Dec 18, 2008 | 09:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by hitmann91
When i bought the car 2 years ago the exhaust fumes were clean, now my car smokes a hell of a lot when i start it/any acceleration. , thanx
What color is the smoke? Blue is oil, black is fuel, and white is coolant. Makes a difference as to what the issue may be.
RBob.
Old Dec 19, 2008 | 09:27 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Also is it when the car starts up after sitting for awhile or does it smoke all the time?
Old Dec 20, 2008 | 12:23 AM
hitmann91's Avatar
hey, thanks for the replys, it is blue oil smoke, and it smokes a little even when idling, but its when i start it/accelerate that i get pretty nice cloud
Old Dec 20, 2008 | 06:59 AM
Car: 1991 Z28
Engine: SBC
then its most likely the piston rings
Old Dec 20, 2008 | 08:22 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
I know what you are going through I have had enough 305's in my life. It could be valve guides, rings, camshaft, and various other things. What you have to do Is a good 'ol fashioned compression test. That will tell you exactly what is going on. You can pick up at Compression Tester up from any auto parts store, tool supplier, etc. for like $25.00 - $60.00 (depends on brand name).
Old Dec 20, 2008 | 09:22 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
dont worry about it, shes old enough to smoke in your shoes i would do a compression test or preferably a leakdown
Old Dec 21, 2008 | 09:21 AM
hitmann91's Avatar
alright guys thanks for the help, ill go pick on up, and post what i find out when i get the new info
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
