Who put the spark plugs there?
Old Feb 5, 2009 | 05:59 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Honestly? You have to do 7 of them under the car.. I think the person who made this should be put in prison, with the man who invented the flat head screw..
Old Feb 5, 2009 | 11:20 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Then into that cell THROW the clown that decided it was a good idea to stamp slot and philips indentations on the same screw head.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 5, 2009 | 01:36 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: Who put the spark plugs there?
there are plenty of 4 cylinder cars with the plugs on top where they are easy to get to. I'll take my 8 cylinder with awkward plug placement any day! It's a great excuse to buy headers. I have very reasonable access to mine from above with headers and no a/c
Old Feb 5, 2009 | 02:18 PM
Kevman's Avatar
Engine: 2004 LQ4
Or Torq heads..
I'd rather take the V8.. But it's all done.. No problems..
Old Feb 5, 2009 | 03:23 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
which is according to my current knowledge in most cases more related to the presence of TWO over-HEAD cams
i agree on the topic, really.. you're right about the headers no changing plugs without putting on headers hehe. plus headers minus emission stuff minus a/c make things a lot easier i suppose..
Old Feb 5, 2009 | 09:28 PM
Kevman's Avatar
Engine: 2004 LQ4
Those metal tubes?! What a pain!
Even putting the wires on was a job.. Took me like.. 45 minutes to sort out where they went, put the fireproof covers on, and set them up.. I used Taylor 8mm wires too, $20 at a swap meet.. Sweet.
Old Feb 5, 2009 | 09:39 PM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
without the air garbage and more exp. u can change'em all in just a few min. easy.
Old Feb 5, 2009 | 11:41 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its not THAT bad. Try changing plugs on a late model transverse V6. They dont use those irridium 100k plugs for nothing.
Consider yourself lucky, at least with the manifolds they can be changed without removing the exhaust. With some shorty headers, to get the plugs out, the headers have to be removed.
Old Feb 6, 2009 | 01:58 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
HA BEEN THERE! i did a compression test and a CLT today and i spent more time trying to get the damn hoses into the threads than i did testing it!
shenanigans!
Old Feb 6, 2009 | 08:03 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
We also have no business complaining if ever talking to a 4th gen f-body owner. Those engine bays are PACKED! I believe changing plugs on those has a book time of over 6 hours. Imagine paying the bill for that?
Old Feb 6, 2009 | 10:41 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
aha yeah did that (well attempted to) i got 4 of them done and then told my friend it wasnt worth my arm getting destroyed by ramming it in there out of frustration, he went to a shop and still paid out close to 300 lol
Old Feb 6, 2009 | 11:53 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
not that bad. the 4th gen v8's are a lot harder. we pulled an a/c compressor off of my buddies trans am to get to them easier. The tranverse gm's are a little tough. The hardest are probably the mod v-8's in mustangs and trucks. especially the ford vans. the thread strip really easy too.
Old Feb 7, 2009 | 12:41 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
yeah i was pissed the first time i changed the plugs on the bird.
used to hondas having the plugs on top but after a few times now used to it.
just throw it up on the ramps lol
Old Mar 29, 2009 | 04:36 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
What kinds of headers are there out there that make reasonable easy access to the plugs? The headers on my car right make it extremly difficult to get to a few of the plugs while a couple it's very easy. Any headers out there that would make easy access to at least most of them?
Old Mar 29, 2009 | 12:07 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Geez sucks to be you guys, lol it takes me 10 minutes to do mine.
Old Mar 29, 2009 | 12:17 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
changing plugs on my car sucks also. I have headers also, so you you can't use the regular sparkplug socket, it wont fit between the headers. The only solution I had was to take the socket and cut it down just above half way so it could clear the headers, and still fit over the plug. Then I have to use a box wrench on the top of the socket to loosen them up. I remember seeing a company somewhere online that actually made these for 4th gen cars but wanted like 20 bucks for it.
Old Mar 29, 2009 | 01:13 PM
Car: '86 Trans Am
Engine: 305 H.O.
I just use the normal plug socket on the plugs it will fit. The others I have to use normal wrenches that are big enough o fit around the plug. It works, but very time consuming.
Old Mar 29, 2009 | 03:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
3rd and even 4th gen plugs are EASY. If you want difficult go with some of chryslers FWD V6 engines (pull the plenum to get the back plugs). 5.0 Explorer (put it on the rack, pull the inner fender liners, and fight it with a wobble). Also my 97 Chevy Express van (rack, pull t he inner fender liners, and use a 2ft extension) was a pain.
Old Mar 30, 2009 | 09:52 AM
kcb37's Avatar
I got all of mine from the top with shorty headers.
Also 1982TA do you have regular plugs in yours? If you put in header plugs you might find that you can use a regular spark plug socket.
Old Mar 31, 2009 | 02:47 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
After I yanked out the AIR junk on mine, I found I could reach 7 of 8 with only mild shoulder dislocation . I hope to get all 8 without jacking the car once I replace the headers.
Old Apr 3, 2009 | 08:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I miss doing plugs on my Camaro. Thanks to the headers, I could do a plug swap in 1/2 an hour with a box-end wrench.
Now I'm stuck with the GTP and they aren't kidding about transverse v6's. I have to pull the engine forward and pull the O2 sensor (or get reallly creative with the wratchet and adapters) to get at those back three. Now I know why it still had the original plugs in back when I got the car at 80k miles.
Old Apr 3, 2009 | 09:10 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I had Edelbrock TES haeders on mine, couldn't fit a ratchet with the socket on it, had to slide the socket over the plug and use a 3/4 box wrench to turn the socket. Could get all but 2 from the top.
HtOwNs 87Rs's Avatar
Changed mines not long ago and were a freakin pita to get to. I have slp headers that were in the way for #6 & #8. Used someone advice about cutting the plug socket in half and using a wrench to turn the hex nut side of the socket to get em off. What a pain.....the new ones were a pain tryin to get started. Poor engineering on those slp headers that came with my car.
Old Apr 21, 2009 | 12:56 AM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
http://www.hawksthirdgenparts.com/ca...dersocket.aspx
Haven't tried these, wonder if they work, suppose to make changing the plugs easier if you have headers.
Old Apr 22, 2009 | 08:56 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
thirdgen plugs get consecutively easier as you own the car longer, more **** flies out of the way the better it gets to know you.
Old Apr 24, 2009 | 11:15 AM
Pocket's Avatar
Car: 91 Trans Am
Do plugs/wires on a LT1 fbody then complain about 3rd gen plugs
Old Apr 24, 2009 | 01:27 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Atleast your not in my boat.
When I bought my car they had left the long plugs on and put the TES headers on and I can't even get a socket on them. I had to break them and then put the short ones on. My 83 was easy with longtubes and no AC or emissions and I could get them all from the top.
Talk about hard try a V6 Fiero and getting the back 3 plugs, easiest way to do it was by laying a board across the plenum and the trunk and laying down and working blind.
Old Apr 24, 2009 | 01:56 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
i think we've pointed this out a few times. Like i said, if you want a real challenge do the plugs on an 02 TA with the LS1, damn near impossible lol
Old Apr 24, 2009 | 02:43 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Depending on the year of the ford mod v8 you are supposed to have a retread kit to change the plugs . Others you don't have too because the threads stay in the heads . The years you have to retread is not something you want to do trust me I use to work as a mechanic .
Old Jun 13, 2009 | 11:41 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
god, thats the problem i had today, i have the TES headers and regular autolite sparkplugs from the previous owner, and i was only able to change 2 sparkplugs, and thats which a slightly shorter socket. im seriously thinking about purchasing that short sparkplug socket that SLP sells for changing sparkplugs on F-bodies
Old Jun 14, 2009 | 12:40 AM
1990z28's Avatar
Car: 1990 Z28 Camaro
Mine are all easy to change i have Hooker shorties and i have a special wrench where its skinny enough i can take a socket and get the wrench in there and the wrench was about 4 dollars at harbor freight.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
