I think my motor might be done, any ideas on a replacement?
Old Apr 6, 2009 | 10:45 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
My current motor wont rev past like 1500-2000rpms and thats when im flooring it.
Any idea on who makes a solid 350 or 383 motor that would be easily tuned in and makes some decent power?
I know cheaping out is bad, but the cheaper it is, the better.
Old Apr 6, 2009 | 10:55 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: I think my motor might be done, any ideas on a replacement?
Honestly I would be looking for simple things. Fuel Delivery, Timing, and crossed plug wires.. Stuff like that.. It may even be that you are trying to run the stock chip on the engine in your signature? That definately will not work.
Old Apr 6, 2009 | 11:07 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Not stock chip. wires are good, im going to check everything out today. But it ran fine earlier that day. Then it started smoking bad and it smelt like tranny fluid and it wouldent rev. Couldent even make it up a hill!
Old Apr 8, 2009 | 03:33 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Everything checks out. Seems like a spun bearing or something. Today I couldent even back it into the garage, it wont even rev up to 1000rpms and it smokes pretty bad.
So no one has any ideas on where I can get a good 350 or 383 for a fair price?
Old Apr 11, 2009 | 06:28 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
JY? If you want cheap. Most junk yards will warranty their motors for a fee. as to say they'll give you 30 days for a small fee. that way you could have it running and know how it runs pretty surely. if it craps out or turns out that it isn't buildable they're obligated to give you one that is.
Old Apr 11, 2009 | 06:53 PM
88iroc52387's Avatar
aside from an autozone cheapy. The cheapest i know of is the universal 350 http://paceperformance.com/index.asp...&ProdID=224002
Old Apr 11, 2009 | 07:00 PM
Heslekrants's Avatar
Car: 1990 Camaro RS
Engine: 5.7L Vortec TBI
Transmission: Built 700R4 2800 stall
Check Craigslist. I bought a 4 bolt main Vortec 350 with 50k miles off of Craigslist for $150 then added 1.6 rockers, headers & intake to replace our dead 305 TBI. Now she'll run high 13s in 1/4.
Old Apr 12, 2009 | 01:06 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
A plugged catalytic converter can cause the described
problem-check that if it is still in place.
Old Apr 12, 2009 | 06:03 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
That was a VERY good call. Apparently cat-co cats suck, because its plugged up after only a year. Im going to just put straight pipe there.
Thanks a ton, if I ever have this issue on a 3rd gen again, ima check the cat for sure.
Old Apr 12, 2009 | 07:31 PM
Car: 1990 Camaro RS
I bought Cat-co cats once & they failed after 1 1/2 years I didn't have those symptoms. I just got a code.
Old Apr 12, 2009 | 08:00 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I had a similar problem on my V6 car a while back, changed the cat.. The guy was just dropping the head shielding to drop the tank, and the neoprene hose was twisted causing low fuel pressure.. It sucked.
drewdock87
South Central
Aug 18, 2015 09:02 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
