Injectors not fireing
Old Jun 8, 2009 | 10:21 PM
ia_wolfac's Avatar
Car: 91 Firebird Formula
Engine: 5.0L TBI
What would stop the injectors in a 91 5.0L TBI from spraying? I have changed the ECM, didn't help. I have checked the fuel pump, its working. I have also pulled the fuel line off at the engine and its getting gas. When I dump gas into the engine it fires off and runs fine, but the injectors wont spray.
Thanks in advance
Old Jun 8, 2009 | 10:25 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Injectors not fireing
The injector pods could be bad, check the resistance of them with a multimeter.
I don't think they're that expensive to replace.
Old Jun 9, 2009 | 12:43 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
#1 Check -> 10 AMP fuse - if there is no 12 volts at injectors.
Old Jun 9, 2009 | 09:08 PM
sllimj's Avatar
the injectors get 12volts anytime the key is on, the ecm controls the ground......
first make sure there is power at the injectors
Old Jun 10, 2009 | 02:22 PM
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
maby ignition module is bad?
Old Jun 10, 2009 | 02:26 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Doesn't VATS inhibit the injectors? (Chip in key security) I know it drops out something fuel related and it's either the fuel pump relay or the injectors. Check to see if the security light come on at start up and then goes off. If it stays on it did not read the chip, if it never comes on then bulb is burnt or electrical problem.
Old Jun 14, 2009 | 06:04 PM
white91's Avatar
Car: 91 CamaroRS convertible
Engine: 305 TBI
Axle/Gears: stock
I have the same problem and have checked all of theos things. I just am not getting power to the injectors?
Old Jun 16, 2009 | 08:12 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
ignition control module, vats, pickup coil and ecm are the only thing that could inhibit fuel at the pods (other than the obvious wiring and connections of course). test your icm with a ohm meter thats where i would start.....
Old Jun 25, 2009 | 12:56 PM
kobrak's Avatar
Car: 1983 Z28 Camaro
Engine: 350 block with original Cross Fire
Hopefully this isn't your problem, but it was mine;( If you say you have gas running out if you disconnect the fuel line.........what happens when you turn the car over? Does the gas now spray out? The reason I ask is becuase I had a seperation at the fuel pump to hard line in the tank. I had to pull the taank to prove it. Once dropped, I pulled the pump and the rubber line (only about 2") was basically all goo and seperated. Sucked!
I would start by checking your fuel pressure.
Old Jun 25, 2009 | 01:04 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
There are a number of things this could be. Check your fuel pressure. Should be about 30lbs. If that is good then check for current at the injectors with the key on. If that is good you have either a bad injector ground or injector.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Ranbo108
Sep 9, 2015 12:20 PM
