HOW TO MAKE MY CARB VORTEC A TBI
Old Jun 10, 2009 | 11:42 AM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
WHAT DO I NEED TO PUT A TBI SYSTEM ON MY VORTEC OR IS THEIR A FORUM I MISSED
Old Jun 10, 2009 | 07:12 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: HOW TO MAKE MY CARB VORTEC A TBI
Vortec style manifold for TBI or carb with a TBI adapter
ECM
Distributer
Patience
Old Jun 10, 2009 | 08:44 PM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
what type of ecm do i need to purchase i have a 86 z-28 t-5
Old Jun 12, 2009 | 06:00 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
I'm lost. What ECM do you have now? There are few different # ECMs and I am no expert on all of them. If you are going to put a different motor in your car than stock, I would suggest getting an EBL from dynamicefi.com. That is what I got when I went 305 to 350. I sent in my stock 90 7747 and had them upgrade it to EBL, but you can have them provide the ECM as well.
What was the stock set-up of your 86? 305 TBI? If so, your ECM will work but you definitely have to re-tune it and for that the EBL is worth it's weight in gold, no, make that platinum with diamond sprinkles.
Old Jun 14, 2009 | 09:01 PM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
the set up when i got the car was 305 carb with some wiring problems
Old Jun 14, 2009 | 09:08 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
To cut down on guesswork why don't you put pictures of your current setup with extensive description and were you want to go from there. Get photos placed on a free hosting service so that full resolution photos can viewed. Otherwise, above mentioned mess will not result in answers.
//RF
Old Jun 16, 2009 | 08:20 PM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
my furture plan is to superchargered what would be the best fuel system tbi, tpi or is there something else that would be better
Old Jun 16, 2009 | 10:14 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
If you have to start over with the wiring, I personally would skip over the TBI and use something a little more advanced.
Are you wanting a roots or centrifigal blower? With roots a carb is a good choice, but a centrifigal will need a good fuel injection setup.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
pimp2303
Jul 27, 2017 02:03 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
