350 Upgrades?
Old Jun 17, 2009 | 09:17 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
350 Upgrades?
What should I do? I got a 350 5.7L from a 1991 chevy 1500 silverado w/ computer, so i'm swapping it over to my camaro, but i'm wanting to do a little work to it, what would be the best options for this tbi to get more power?
Old Jun 17, 2009 | 11:34 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: 350 Upgrades?
Do you plan on doing any tuning? That will determine what can/should be done to the motor.
Old Jun 18, 2009 | 05:46 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 350 Upgrades?
Would it be easy for me to know how to tune? I would prefer to tune later!
Old Jun 18, 2009 | 10:09 AM
Ronny's Avatar
Re: 350 Upgrades?
This thread was started to help those that are beginning tuning. after checking it out read the stickies in DIY-PROM. there is one there that give you more of a technical reference to tools you need and terms you will run across.
Easy? I stuggled with Geometry but found Algebra easy.
Old Jun 18, 2009 | 07:44 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 350 Upgrades?
sucks its so expensive to work with the prom setups wish i knew someone that could teach me right here...
Old Jun 22, 2009 | 11:58 AM
Ronny's Avatar
Re: 350 Upgrades?
Ask a question and you will get an answer. This board has the experience.
All the help you need is waiting.
Old Jun 22, 2009 | 06:29 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 350 Upgrades?
i just posted in the swap thread because now i'm questioning if its going to work. i'm swapping over the computer w/ prom and the complete 350 tbi engine from the 91 chevy silverado 1500 to my 89 camaro 305 tbi, anything i should look to be swapping or buying new? both have the 700r4's so i don't see a problem but maybe the wiring?
Old Jun 23, 2009 | 06:06 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 350 Upgrades?
https://www.thirdgen.org/forums/tbi/...ucks-have.html
i pulled this up and a few others say don't have to worry, everything should be fine... but i'm still researching to get an exact idea.
Old Jun 23, 2009 | 11:16 AM
Ronny's Avatar
Re: 350 Upgrades?
ESC module or knock sensor from 350 cid
ignition module for 350 cid
I believe the harness-ECU is compatible. If not I recall Turbo City may sell an adapter? Check their site for info
89 camaro I think has IAT. check if the 91 truck has same. If not it has to be turned off in chip.bin
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
