shorted coil power wire and burnt ign. switch now starts hard??
Old Jul 31, 2009 | 05:11 PM
cretecrawler's Avatar
Car: 88 firebird(305), 82 s10(350)
Engine: 305 tbi
Axle/Gears: stock
had a mishap where the aftermarket air breather rubbed a hole in the coil power wire and burned out the fusable link at the starter and the power wire under the dash from the ign switch to the fuse panel... oh yea and the ign. switch. Still got continuity through the red wire from the ign switch to the fuse panel so to get the wifey on the road quickly i replaced the fusable link and the ign switch but now it takes forever for it to start... like maybe the TBI is not giving that initial squirt of fuel not very schooled in the finer art of FI so be easy on me please... the wifey swears that if she pumps the pedal a few times on that TBI it will start easier , to save the arguements, I just agreed
Old Jul 31, 2009 | 06:32 PM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
Re: shorted coil power wire and burnt ign. switch not starts hard??
Check your fuse panel for fuses that may have blown when the short happened.
Old Jul 31, 2009 | 06:48 PM
Engine: 305 tbi
Axle/Gears: stock
yea, went through all the fuses one by one with a fuse checker... i was hoping for that in the beginning
Old Jul 31, 2009 | 08:05 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Once started and running, check it with a timing light to make sure the advance is working properly.
Old Aug 1, 2009 | 09:14 AM
Engine: 305 tbi
Axle/Gears: stock
the advance will affect the initial squirt of fuel??
Old Aug 1, 2009 | 12:27 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: shorted coil power wire and burnt ign. switch now starts hard??
There shouldn't be any squirt of fuel until the ECM sees a certain number of DRPs from the distributor, which tells the ECM how fast the engine is spinning. The ECM also uses this to determine spark advance.
Old Aug 1, 2009 | 01:10 PM
Engine: 305 tbi
Axle/Gears: stock
hmmmm tell me more... newbie to FI here, always been a carb man... so far
Old Aug 1, 2009 | 06:41 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The turning distributor creates the reference pulses (DRP's) when cranking. The ECM needs contact with the distributor to determine engine speed for many functions. When the ECM sees the RPM get close to 400 - 450, then it starts delivering the cranking fuel, which contains much extra fuel. That's the fuel that starts the engine.
Normally the ECM bases spark advance on the DRP signal from the distributor. If it loses connection with the distributor, then it goes into a default mode. The distributor may still function on base timing alone, but the ECM will not be able to add any advance. No advance would suggest a lost connection there.
If you hold the throttle open past a certain TPS%, then it goes into "clear-flood mode" which reduces the amount of cranking fuel by a lot.
Datalogging or hooking your ECM up to a scanner may help in determining what is wrong.
Old Aug 1, 2009 | 06:58 PM
Engine: 305 tbi
Axle/Gears: stock
"Datalogging or hooking your ECM up to a scanner may help in determining what is wrong."
I saw, somewhere in a thread on this forum, a link to a program download for datalogging... what is the required equipment for this operation? Sorry, again I am a newbie to automotive computers and FI... please forgive the virgin...
Old Aug 1, 2009 | 08:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Go to the DIYPROM section and read the stickies.
Or you could find someone local who is already set up to do it.
Old Aug 1, 2009 | 08:03 PM
Engine: 305 tbi
Axle/Gears: stock
great, thanks...
BRoss99
Aug 10, 2025 05:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
ZsTransAm
Aug 11, 2015 07:30 PM
L98GTA87
Aug 5, 2015 11:02 PM
