Walbro or tpi pump
Old Nov 3, 2009 | 09:38 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Walbro or tpi pump
getting a mild build: vortec heads, intake, mild 298/298 duration cam. with the 5.7 injectors, which pump should I get? Is the 305 tpi pump enough, or do I need a walbro 190?
Old Nov 4, 2009 | 01:22 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Walbro or tpi pump
Either one should work. Dont know what the flowrate is on the TPI pumps, but I would imagine that at around 14-20 PSI, it should flow enough.
Old Nov 4, 2009 | 12:11 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I'd go with the Walbro so you have no worries later on if you need more fuel. Dropping the tank is alot of work. I'm running the Walbro 255.
Old Nov 4, 2009 | 07:40 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I am currently using a pump from Harris Performance. It's 255pph which is ~40psi @ 12v. It is under $100 shipped.
Old Nov 4, 2009 | 10:12 PM
92 Camaro's Avatar
I would think a 255 is overkill if I would be running around 20 or 21.
Old Nov 5, 2009 | 05:22 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I would recommend a Walbro 190lph pump. This pump at TBI fuel pressure can support ~450hp and you will have no prob getting the fuel pressure down like you would have if you threw a 255lph pump in your tank. (assuming your running around the stock fuel pressure) If you plan on bumping the FP up to upwards of 20psi+ then I would suggest a 255lph.
Old Nov 5, 2009 | 08:47 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Doesn't the tbi have a return style FP setup? I always thought that the regulator cut it off at the predetermined PSI and just returned the excess to the tank. I could be wrong though.
Old Nov 5, 2009 | 11:01 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
That is true. However the return line for the TBI setup is designed for the stock pump flowing ~13 psi. With a 255lph pump in the tank so much fuel is being deferred to the return line that it cant keep up with the pump, raising the overall fuel pressure of the system. In short, the return line is too small for the 255lph pump at stock fuel pressure.
Old Nov 7, 2009 | 07:19 PM
92 Camaro's Avatar
is it too small with a 190? and is the feed line ok?
Old Nov 8, 2009 | 12:02 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
190lph pump is much more practical for a tbi setup
Old Nov 8, 2009 | 09:55 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I got a 190 for sale. In car right now, but bird is going on the choppin block real soon.
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
