the right throttle body
Old Nov 9, 2009 | 11:32 PM
tanda10506's Avatar
Ok, so after the info I gathered from you guys so far I decided I'm going to make a 383 stroker and use a carbureted intake and TBI adapter. But where can I find a throttle body unit that will support roughly 450 HP?
Old Nov 10, 2009 | 11:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: the right throttle body
Get either a BBC TBI unit or a Holley 670 CFM unit. Just do some research first on which one to get. The later BBC units used small injectors at high pressure. No room for growth.
The early Holley units used Chrysler injectors which are terrible. Be sure if you get a used Holley that the injector leads exit the injector from the side.
RBob.
Old Nov 10, 2009 | 04:06 PM
tanda10506's Avatar
So an earlier BBC throttle body will handle that much horsepower? I don't mind spending some money on a new one if I need to, I just want the unit to support the power.
Old Nov 10, 2009 | 04:16 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I got a new 2" tbi and 90# injectors from xtremEFI that was on my hotcam 350(Actually still on). Read up on it and see if it will work for you. It only has about 10k on it.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
