hey i just got my weiand team-g intake manifold in the mail today. im still getting parts for the rest of my engine.
anyways.....
im living in Rexburg, ID where it sometimes gets in the teens below zero in the winter months. i have heard some people complaining about icing up in the throttle body. im wondering if there is a heated TBI to 4bbl adapter out there that would help me cure this
or
if anyone out there has driven a Single plane TBI in the winter and the results they had
thanks
anyways.....
or
thanks
i think i read somewhere about a stock GM 454TBI adapter plate that was coolant heated? anyone have a P/N or link?
I have seen one, but it won't bolt up to your manifold, a team G has a squarebore flange, the truck adapter has a Qjet flange IIRC, go to the local junkyard and look for suburbans and 3/4+ ton trucks.
yeah i read that, but i guess i could make adapt the q-jet to squarebore flange
also what years did they come in?
All smallblocks went fuel injection in 1987, I think bigblocks went in 88 or 89, but TBI was optional on earlier models IIRC.
Originally Posted by gravedigger472
yeah i read that, but i guess i could make adapt the q-jet to squarebore flangealso what years did they come in?
I hope you don't plan to run the stock hood with all of those adapters on top of a team G.
well its going on a truck that has more clearance than a f-body
but im not sure what clearance issues i will have. ill make it fit one way or another.
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:509 Times in 437 Posts
Quote:
anyways.....
or
thanks
Just put the stock air cleaner housing on it with the heat stove pipe. It will keep the TB from icing. Atleast it did on my Edelbrock 2912 Victor Jr 2bbl.Originally Posted by gravedigger472
hey i just got my weiand team-g intake manifold in the mail today. im still getting parts for the rest of my engine.anyways.....
or
thanks
is there an easy way to convert headers to work with the heat stove?
Doesn't the TBI already have coolant heating?
Quote:
Originally Posted by Saabster
Doesn't the TBI already have coolant heating? only TPI has a heated throttle body, on a tbi motor, the intake is heated which transfers to the TBI
I ran a weiand accellerator single plane for 2 seasons(store car 11/20) in wisconsin. BUT it was with Xram plenum so it therefore is doubly bad and not in a good way. I will suggest it will be very cold blooded. I needed to let car idle for maybe 3 minutes and still had drivability issues until 10 min of driving. I think Holley used to sell a coolant supplied adapter plate. Check their site.
robertfrank
close
- Join DateApr 2004
- LocationSalt Lake City, Utah
- iTrader Feedback Score(27)
- Car1988 camaro "SS"/ 1991 305/T5
- Engine383 LT1 in progress/LT1TBI 355 soon
- TransmissionProbuilt 700R4 3600 stall/ T5
- Axle/GearsMoser axles, 3.42 Eaton Posi
- Liked:62 Times in 44 Posts
Hell with my 3704 tbi intake my car I'm still having a bitch of a time tuning AE in this cold weather. I have to let it warm up for like 20 minutes or it runs lean as hell. So I can imagine it;s going to be a bit of a bear to get right
do you have the IAT sensor installed? im wondering if this would help cold issues or not.
I run an IAT. When cool on coolant <180d it runs off open loop tables coolant based A/F. IAT is helpfull. Once it hits 180 it flips closed loop and IAT helps again but only to a degree. Issue is fuel falling out of atomization if the manifold/TB is cool. I dont think IAT can help in that regard. You would need coolant crossover under manifold which my heads do not provide. Also a heat riser which again I do not have. I think this issue is also present in carbed cars in cold environment.
