91 RS RUNNING WAY TO RICH CANT IDLE.
Old Jan 23, 2010 | 05:44 PM
anthonyrs's Avatar
Car: 1991 CAMARO RS,1997 FORD EXPLORER
Engine: NO MORE 305. 350 NOW
Axle/Gears: 273 NEED NEW ONES
I HAVE A 1991 CAMARO 305 TBI AND IT WAS RUNNING MINT THEN ALL OF A SUDDEN IT STARTED TO RUN VERY ROUGH WHERE I HAD TO HOLD THE GAS PEDEL DOWN. I HAVE SPENT ALOT OF MONEY SINCE THEN I BOUGHT, NEW MAP SENSOR,TEMP SENSOR,PLUGS,WIRES,NEW DISTRUBTUR,CAP ,ROTOR. PLUGS ARE BLACK. I CHECK THE FUEL PRESSURE IT WAS AT 10. THE ENGING HAS A EDLEBROK CAM, HEADERS WITH Y-PIPE. NO CAT. NO EMISSIONS STUFF. LIKE I SAID THE CAR WAS RUNNING GREAT INTO ALL THIS HAPPEN. I SWITCH A USED TBI WITH SENSORS AND THAT DID NOTHING. ANY HELP? THANKS
Old Jan 31, 2010 | 09:21 AM
tealrs's Avatar
Car: 1991
Engine: 454
Transmission: 4L80E
Axle/Gears: s60 3.73 true trac
Re: 91 RS RUNNING WAY TO RICH CANT IDLE.
seeing that your other post was about the distributor i would check your timing and recheck to make sure your wires are in the right order very easy to switch two by mistake.
Old Jan 31, 2010 | 10:02 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
also ck. ALL vacuum lines , easy enough to break/disconnect 19 yr. old hoses & plastic . good luck .
Old Feb 7, 2010 | 10:41 AM
anthonyrs's Avatar
I THINK I FOUND MY PROBLEM. I TOOK OFF THE VALVE COVERS AND THERE WAS A LOT OF MILKY SUBSTANCE ON THE TOP OF ONE OF THE VALVE COVER AND WATER MIXED WITH OIL IN THERE. SO TOMORROW I WILL TAKE THE HEAD OFF.
Old Feb 7, 2010 | 11:39 AM
Dennis79Formula's Avatar
Car: 1979 Pontiac Firebird Formula
Engine: 355 Chevy
Transmission: Turbo 350
Once you fix that and it still runs like that unplug the coolant temp sensor by the thermostat housing my 91 use to eat these sensors up and would run like ****
Old Feb 7, 2010 | 01:37 PM
Pocket's Avatar
Car: 91 Trans Am
Unplug the CTS and see if the richness goes away
Old Feb 7, 2010 | 07:20 PM
tealrs's Avatar
Car: 1991
Engine: 454
Transmission: 4L80E
that mily substance is oil mixed with water it can be "normal" in cold climates. it is condesation forming in your engine. do you drive a lot of short distances? i have had that with a few engines wipe it out drive around and it will be back. i wouldn't pull the head off unless you are loosing alot of coolant or have a cylinder that insn't firing. mabee try taking the spark plug wires off one at a time and start the engine and if you find one that dosen't change the way it is running thats your bad cylinder, pull spark plug first. dont want to make extra work. maybe drain the oil put new in.
Old Feb 7, 2010 | 07:47 PM
anthonyrs's Avatar
THANKS FOR THE GREAT INFO. I COULD IT EVEN CHECK THE WIRES LIKE THAT BECAUSE AS SOON AS YOU LET GO OF THE GAS IT WOULD STALL. I DID PULLED THE ONE HEAD OFF TODAY AND IT HAD WATER IN THREE CYLINDERS. I KIND OF WAS HAPPY TO SEE THAT. BUT A LITTLE **** OF BECAUSE I JUST PUT THESES HEADS ON ABOUT 100 MILES AGO. THEY HAD OR I WAS TOLD THEY HAD AROUND 80000 MILES ON THE HEADS. THE PERSON GAVE ME ONE BRAND NEW GASKET FOR THEM AND TOLD ME I WOULD'IT USE THIS ONE. SO WHAT DID I DO I USED IT AND BOUGHT ONE NEW ONE. AND THAT WAS THE SIDE THAT WHENT. I DONT KNOW IF IT WAS THE HEAD IT SELF BUT I DONT CARE I AM GOING TO REPLACE BOTH OF THEM. I SHOULD OF DONE THIS IN THE FIRST PLACE INSTEAD OF CLEANING UP OLD **** ONES.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86IROC112
Aug 17, 2015 02:00 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
