help with tv cable on throttle body!!!
Old Mar 11, 2010 | 11:34 PM
nickvott91rs's Avatar
Car: camaro
Engine: 350 tbi
Axle/Gears: stock?
got a 91 rs with a 92 350 tbi motor and i forgot which hole the t/v cable goes in on the bracket is it the top one or the bottom one pictures would deff help please! thank you
Old Mar 12, 2010 | 12:34 PM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Re: help with tv cable on throttle body!!!
If I recall correctly, each cable only fits in one hole in the bracket, you can't mess it up without modifying something. The portion that 'clips' in is different for the cruise, throttle and tv cables.
http://cgi.ebay.com/ebaymotors/JET-P...item4cee2646c7
Whichever hole looks like this is the right one.
Old Mar 12, 2010 | 11:35 PM
Car: camaro
Engine: 350 tbi
Axle/Gears: stock?
i have whatever came stock bracket how i think it should be is bottom-tv cable middle throttle cable and top empty right?
Old Mar 12, 2010 | 11:45 PM
Engine: L98, LG4
That sounds about right, but like I said, you can't screw it up, they only fit together one way, just look at the part on the cable that clips into the bracket and you will see what I mean, they are designed to be fool-proof.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
