timing
Old Apr 6, 2010 | 06:59 PM
joshwilson3's Avatar
timing
What is the timing supposed to be for an 89 305 TBI? I've read it could be 0* or 6* advanced. I believe last I had it in the shop to get the timing set, I believe they put it at 6* advance. I only use 87 gas. Just wondering where it is supposed to be set at?
Old Apr 7, 2010 | 03:42 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: timing
0*
Old Apr 7, 2010 | 12:26 PM
Re: timing
Originally Posted by thomas1976
0*
Thanks, I'm gonna set it to 0*. I'll have to wipe up the oil from the timing tab that is all over it.
Do you by any chance know of a pic that shows where that bolt is your supposed to put your wrench on to be able to adjust the distributor?
Old Apr 7, 2010 | 02:42 PM
Re: timing
How are you supposed to read the timing mark? From the top, or at an angle by the alternator? I've noticed the timing mark can look like it is set different depending on how you look at it.
Old Apr 8, 2010 | 08:39 PM
Re: timing
Well I guess it don't matter as that bolt on the distributor won't turn. It is set at 6*. You can't get a socket to it. And you can barely get a wrench to it. And you really don't have much room.
Old Apr 8, 2010 | 09:45 PM
vettedreams2001's Avatar
Car: What don't I drive
Engine: 305 tbi
Re: timing
They do make a special wrench for that if you're having too much of an issue getting an open end on it, you could pick up the special one at harbor freight.
Old Apr 9, 2010 | 01:15 PM
Re: timing
I'll have to look. I can get the wrench on there, but I don't have enough room to turn the wrench as it appears that bolt isn't wanting to move. And when trying to turn, I have maybe just a 1/4" to turn it, and the wrench pops off the bolt.
Then I tried putting the wrench in on the driver side, but I only had enough room to use my thumb to try and turn the wrench, but it wouldn't budge.
Do you have a part number for that wrench on HF? I couldn't find it.
Old Apr 9, 2010 | 07:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: timing
any auto parts store carries the distributor wrench.
Old Apr 11, 2010 | 11:02 AM
Re: timing
I got it set to 0*. That distributor wrench sure did make it easy. Thanks.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
