Manifold Vacuum port
Old Jun 8, 2010 | 07:25 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
Is the manifold vacuum port supposed to be plugged. I have a 305 TBI. If it is not supposed to be plugged what should be routed to it. Pics would be helpful.. Diagrams are unclear to me. Thanks.
The port is located next to egr..
Old Jun 8, 2010 | 07:45 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Re: Manifold Vacuum port
all ports that are not in use need to be plugged, or else ur gonna have a vac leak and will make ur car idle funny.
Old Jun 9, 2010 | 12:06 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Right, i figured that. But is it supposed to be connected to something. I had the motor all apart and outta the car.
Old Jun 9, 2010 | 02:27 PM
Ronny's Avatar
Power Brake Booster ?
Old Jun 9, 2010 | 03:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You're talking about that little silver colored six-sided fitting between the Egr valve and the distributor aren't you? It goes to a little plastic valve and then black plastic vacuum lines ? Just checking.
Old Jun 9, 2010 | 09:42 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If the port you mean is the one I described in my last post, it goes to the bottom of a plastic valve that splits off in two directions. One side connects to a black plastic vacuum line that goes into the wiring harness right by where the one that controls the heater valve comes out. The other side goes way up to the front of driver side and divides between cruise control thing and round plastic globe like thing under the charcoal canister. Not great on the terminology, but maybe this helps???
Old Jun 10, 2010 | 01:24 AM
DSGx's Avatar
Engine: 305 TBI L03
ur gonna have to post a picture of what u mean dude cuz rly theres just so many vac ports on a tbi lol
Old Jun 10, 2010 | 02:51 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, if you're still wondering?? basically that port supplies vacuum for assorted accessories. If you have just a race car and need none of that just plug it. Otherwise, if you want HVAC controls and other stuff controlled by vacuum you want to hook it up. If you have any more interest in needing info LMK
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Rally Smith
Sep 14, 2015 06:59 PM
m00n420
Sep 11, 2015 02:39 PM
