New to TBI help please..
Old Jun 29, 2010 | 03:27 PM
Josh4036's Avatar
Im new to this stuff and this is my first 3rd gen camaro. Its a 91 rs. My pedal is really hard to push down and i can tell the the blades in the tbi are stickin a little when they are fully down. Ive read that you have to adjust the IAC to not let the blades go completely down. The thing is is that i have no idea on how to adjust it. Anyone have a tutorial on adjusting it? Any help is greatly appreciated. Thanks
Old Jun 29, 2010 | 04:07 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: New to TBI help please..
There is a adjusting screw on the TB to adjust the blades, IAC does not control the blades, only the trottle cable does.
Old Jun 29, 2010 | 04:12 PM
Josh4036's Avatar
Like were at on the TB..sorry for the dumb questions im just really new to this type of motor...
Old Jun 29, 2010 | 04:37 PM
thomas1976's Avatar
Car: 91 Trans am
You cannot miss it if you look at the TB, front driverside. The screw its the trottle linkage stop.
A repair manual is cheap and a good investment
Old Jun 29, 2010 | 04:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
https://www.thirdgen.org/tpimod2 This is from the technical articles section. Lots of handy stuff there
Old Jun 29, 2010 | 05:21 PM
thomas1976's Avatar
Car: 91 Trans am
If you look at a TBI or TPI TB you will notice the blades work only machanically.
The TPS just informes the ECM were the blades are.
The IAC controls the quantity of air entering the TB wen the blades are closed. Look at the IAC valve at idle, you will figure out quickly how it works.
If your blades are sticking, IAC sensor is not involved, thoug a really bad TPS could cause similar simptom.
Old Jun 30, 2010 | 02:41 PM
Ronny's Avatar
could be dangerous if it sticks wide open. Like a Toyota. Take off cables and run TBI blades with hand and see if it sticks. Maybe cable sheathing liner is well worn?
Old Jun 30, 2010 | 06:52 PM
Josh4036's Avatar
Oh no its not sticking wide open lol.. Its just when i stop completely its a bit harder to push the gas and i noticed the blades stick a bit when i let the blades close completly. When the pedal is past the stick it just fine.
Old Jul 12, 2010 | 11:37 AM
Ronny's Avatar
If you chose to open the blades at idle then you will need to reduce the IAC steps accordingly. I recall I see 5 steps at idle for IAC. stock.bin may show more.
Old Jul 12, 2010 | 01:13 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
THROTTLE BODY CLEANER
Buy a can of throttle body cleaner and generously spray the blades, with engine off, at all positions, blast out the vacuum ports at base of TBI. also spray the external (directly outside of TBI) linkages and springs (IAC, throttle cable, all of that stuff) to free up gunk dirt grease or residue
Old Jul 12, 2010 | 04:49 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
could be that the throttle shaft bushings are so worn that the shaft and the blades are skewed in their bores.
remove the air cleaner and disconnect the cable.
move (open) the throttle while wiggling the linkage and the shaft...see whats binding.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
