Cams for a L03 305 TBI
Car: 1992 Camaro RS
Engine: Was L03 305 TBI...now BB 454 :)
Just wondering if anyone can help me pick a good performing cam for a stock L03 305 with TBI. I'd like to go cheap, but you get what you pay for so I'm open to anything. I know LT1 Cams are good choices from what I've read, but can't seem to find one to where I won't have to do anything to the engine. I just want to swap a new cam in....
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cams for a L03 305 TBI
why? there's nothing to be gained from it unless you've done full exhaust and intake issues first.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Cam swap is not that cheap of a mod, it requires tunin, fueling upgrades, 3.23 &up gears and a torque converter would be nice too.
I would start with exhaust and aircleaner upgrades like camaronewbie pointed out.
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Checkout the ramjet cam. It has less duration so my be an easier tune. Don't forget all the other parts you would need. Timing chain, valve springs, gaskets, fluids, etc. If you have headers first you will get more significant gains.
Car: 1992 Camaro RS
Thanks for all the tips and advice, but couldn't I swap the LB9's cam in, or is it the same exact specs? Would I have to do anything else to the engine to swap that one in, do you think it would make a difference really? I've heard that swapping the heads off that engine onto a L03 is a good idea too, anyone know about that?!?
Car: 1991 RS Camaro
Engine: 350 TBI
Some LB9's have the same peanut cam and some have the L98 cam so it all depends. It would be wise to still change your valve springs and do a timing chain to be safe while swapping cams. You still have to go through a ton of work for little to no gain without a full exhaust and a tune. Your best time and $$$ would be spent on full exhaust and rear end gears. You will notice the difference and be ready for further engine mods.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Ask and yee shall recieve, check page 3 of my car domain. I have the whole list of popular cams there. but just to be a nice guy I'll post them here.
Stock L03-L05 camshaft 10088155 179/194 - .350/.384 109 LSA
Stock cam W/1.6 rockers 10088155 182/197 - .373/.410 109 LSA
L31 or B-body LT1 camshaft 10243779 191/196 - .418/.430 111 LSA
88-89 L98 camshaft 10066049 207/213 - .415/.430 117 LSA
93-95 LT1 camshaft 12551705 202/207 - .450/.460 116 LSA
Production LT4 cam 12551142 203/210 - .476/.480 115 LSA
ZZ4 camshaft 10185071 208/221 - .474/.510 112 LSA
LT4 Hot cam 24502586 218/228 - .492/.492 112 LSA
Car: 1992 Camaro RS
@robertfrank...on your car domain, you say the 7101 Edelbrock RPM intake is a good choice, but I have a 1992 L03, would it still work? Jegs says it's for a non-EGR motor. I'm not a big wealth of knowledge when it comes to motors...
it will work just fine as long as you get an adapter plate
Car: 1991 RS Camaro
Engine: 350 TBI
Car: 1992 Camaro RS
is the adapter plate you're talking about the same one right below the manifold on your car domain? Also, as UnderCover89TBI said, will the EGR still work?
yes it is the same plate that i have. unfortunately the EGR will not work. I have mine deleted. I also have a hole in my hood from when I had the TBI Spacer. I really haven't checked to see if the Air Cleaner sits too high.
Car: 1992 Camaro RS
what's a fairly easy way to tune these cars for someone like me with no experience? What kind of tools/programs/etc. should I get?
The EBL Flash, a good wideband and a laptop. nuff said.
more than nuff said.
Option #2 less costlyand the way I started is with a chip burner / eraser but now there are other alternatives. See craig moates website.
read the stickies above as well. a must.
Car: 1992 Camaro RS
Well I've got a laptop, but I'm not really sure what any of that other stuff is, sorry.
Check out stickies above. Lots of info to read. Read a little every day. Also see "come in for free tune " in TBI board. Some is basic 101. Lots of info to read.
Car: 1989 Firebird Formula
Engine: 5.0L 305; L03 SBC; TBI
Transmission: 700r4; A4 w/ Overdrive
Axle/Gears: Stock (2.73)
