Open air element.
Old Aug 26, 2010 | 08:16 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Open air element.
Where can I find a good open air element for my LO3? I looked on ebay, none, and Hawks only has one for TPI it seems. Anyone know where I might find one?
Old Aug 26, 2010 | 08:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Open air element.
No promises that they'll all fit under a stock hood, but here's 283 of them to check out. http://www.summitracing.com/search/P...rd=air+cleaner
Old Aug 26, 2010 | 08:53 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Dont get the one with the dropped base, I had problems with it and my cruise control cable that caused my throttle to get stuck, Get a raised or flat base cleaner and you should be good. As for fitment under the stock hood, I had a 14x3 drop base from Edelbrock that is carried at autozone and mine rubbed on the insulation of the hood.
To be honest, I would not reccomend a open air filter under a stock hood, search the forum and find the cai mod which to be honest would be better in the end.
Old Aug 26, 2010 | 10:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can run a flat or slightly raised base - but you can't run a 3in element, you have to drop to a 2 in, and even then sometimes need a 1/2 spacer (Mr. Gasket sells the spacer). Also, the tops always point upwards like a slight cone - this makes them hit the hood - if you gently flatten the top, then you get another 1/2in clearance.
I'm assuming in the old days they made the tops conical so that water ran off the sides instead of down the stud hole into the carb - we're not getting water under the hood these days so no need for the cone top - but the design remains.
Just stay away from the foam jobs, like the Holley or Edelbrock "triangle of death". One good backfire and the foam catches fire, melts into the TBI, and ruins it, gets sucked in the intake and now you have melted plastic in your cylinders.
Old Aug 26, 2010 | 10:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They were conical so you could tighten the wingnut without dishing in the lid.
Old Aug 26, 2010 | 10:45 PM
Car: 1992 RS
Engine: Carbed 350
Oh, OK - I dished my own lid (well, flattened it, not really dished it) to get the clearance and it works well.
I guess you could also dremel cut the sides off a stock housing, that would be open then, and would be guaranteed to fit.
Old Aug 26, 2010 | 10:53 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I can understand your interest in a open air element. Even though I have herd some negative aspects about them I really like mine. With the cowl hood I was able to use the x-stream top. Mine is a 14in. by 3in. with a drop base and a 1/2in. spacer to keep it off the linkage and coil. I found it at Summit Racing on line.I have also seen different styles at your local Advanced Auto. (A coil in the stock placement is fairly close to the bottom plate so I suggest plastic wire looms etc. so you don't make contact.)
Old Aug 27, 2010 | 12:08 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
that look like the goodmark cowl hood right? the 14x6 wouldnt fit under my hood. hit the back of the hole in the hood. im going to make a custom air cleaner setup for it anyway so yeah. but damn that red car looks good!
Old Aug 27, 2010 | 02:24 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I had a 3.5 inch filter in my car when I bought it. Fairly pointless, but I bought it that way:
That was when it was stock. The wingnut was eating the mat on the hood, but other than that it fit fine. had a drop base on a half inch spacer under the throttle body.
You def dont need a 3.5 inch tall filter, though.
Old Aug 28, 2010 | 03:14 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I say you run the biggest air cleaner you can fit, so if 3.5 is it then that's it
Old Aug 28, 2010 | 03:32 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I have the edelbrock drop base for many years and its great. You can do it if you leave the spacer ring on the tbi unit. It will rub the coil plug wires though which is the only issue. I picked it up at my local auto parts store for cheap. You will have to plug the vacuum hose to the tbi which is for the thermac on the stock air cleaner. You will also need to remount your air temp sensor inside the new air cleaneror in the engine bay somewhere. My wingnut just touches the hood insulation.
Old Sep 2, 2010 | 03:03 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
I'm running the 14" drop base on mine too. Started with a 2" filter then used modeling clay on top of the lid to determine hood clearance. Have a 3" filter now with Xtreme top.
Old Sep 2, 2010 | 03:16 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Why run a drop dase and a spacer, when you can just use a flat base and remove the restrictive spacer?
Old Sep 2, 2010 | 04:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A flat base may not clear components on your engine.
Old Sep 2, 2010 | 04:43 PM
krisb410's Avatar
Huh???? A drop base with a spacer fits, but you think a flat base w/no spacer doesn't.
It does fit, I know cause I have a flat base w/no spacer. 14x3 clears the coil and the hood.
Old Sep 2, 2010 | 10:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, your particular air cleaner fits your particular engine. Others may find that a different combination won't clear the coil, throttle linkage, float bowls, EGR valve, choke thermostat, breathers, or whatever else might be on their engine.
Old Sep 3, 2010 | 11:50 AM
krisb410's Avatar
Could be said about any air cleaner as well. As a mateer of fact, could be said about almost every aftermarket part on any make/model. I was stating with a stock L03, you can use a flat base, while getting rid of the restrictive spacer.
Brinkkl2000
Aug 4, 2018 08:29 AM
Todd84Z
Sep 4, 2015 08:02 AM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
