new to tbi
Old Sep 29, 2010 | 01:03 PM
vettsfan's Avatar
From: Home is La Joya Texas- right now Qatar Sand Box
Car: 91 Formula, 91 RS/SS, & 95 Cobra
Engine: TPI 305, LS1, & 5.0
Transmission: 700r4, 4l60e, & 4spd auto
Axle/Gears: 3.73, 3.73, & 3.73
new to tbi
hi i just got this engine 305 tbi not looking to get a alot of hp but might need to get some parts to look a lil nice anybody have recomendation aon what i could delete and the engine bay look cleaner.
want to keep the a/c and heating.
can i delete the egr with out any problems?
Old Sep 29, 2010 | 02:31 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: new to tbi
Do a , and check out the tech articles link on the homepage.
There are a lot of helpful threads, tech articles, and knowledgeable people on this site.
Welcome!
Old Sep 29, 2010 | 02:42 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: new to tbi
For what reson would you like to delete EGR?
Old Sep 29, 2010 | 02:48 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: new to tbi
X2. The EGR when functioning properly has no effect on WOT power and deleting it on a stock engine can cause valve damage due to excessive combustion temps. Unless your running aftermarket heads with stainless valves and a retuned ECM, I recommend you keep the EGR in working order.
Old Sep 29, 2010 | 03:20 PM
1fastcamaro88's Avatar
Car: 1988 camaro sc
Engine: nasty 305 tbi,tba 632 big block
Re: new to tbi
my friend deleted his egr for some reason or another on his camaro and it didnt turn out too pretty.
Old Sep 29, 2010 | 05:51 PM
vettsfan's Avatar
Re: new to tbi
well reason for deleting the egr is cuz im putting hears and the headers dont come with the egr
Old Sep 30, 2010 | 10:55 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: new to tbi
I run headers and still have EGR. Your headers shouldn't have anything to do with EGR unless you run vortec heads and need to plumb them to your exhaust.
Old Sep 30, 2010 | 05:11 PM
thomas1976's Avatar
Car: 91 Trans am
Re: new to tbi
AIR and EGR are 2 completly different things.
Old Sep 30, 2010 | 05:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: new to tbi
DITTO. Souns like youre confusing AIR, with the pipes to the manifolds, with EGR, which is all in the intake manifold and heads. If youre using aftermarket heads(stainless valves), you can run without EGR if you like. However, your stock ECM program may have issues with it. The stock fuel map is very lean. The EGR prevents high combustion temps to help allow these lean mixtures. Without EGR you will run high cylinder temps.
You can overcome this by lowering coolant temp and richening fuel mixture. The cheapest way to do this is a 160f thermostat and fan controller, or fan temp switch, and an adjustable FPR to increase fuel pressure.
Old Sep 30, 2010 | 07:25 PM
vettsfan's Avatar
Re: new to tbi
reason i ask is cuz the stock manifolds i have have a some wierd little tubes inbetween the manild and the headers that i already got dont
Old Sep 30, 2010 | 07:29 PM
vettsfan's Avatar
Re: new to tbi
thinking about adding some more mods to my lil 305 tell me if they are any good thanks.
Pullies
Air cleaners K&N
cam LT1 is it possible?
and rebuilding the engine still want to the 305 dont want to go any bigger love the gas milage full tank last me almost 2 weeks.
i will take nay suggestions just dont tell me to go 350 cuz i wont.
Old Oct 1, 2010 | 06:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: new to tbi
Edelbrock makes a better flowing intake manifold. You said youre going with better heads. Im not sure about the LT1 cam. You might try Comp Cams cam selection program. You can download it from there website. And of course a good set of 1 5/8 headers.
Im fairly certain that the tubes youre talkng about are AIR system. That you can delete. It is strictly an emissions device designed to lower HC emissions by injecting fresh air into the manifolds/cat. The tubes in the manifolds only operate for about 1-2 minutes after a cold start to help heat up the exhaust manifolds. After that the air switches to the cat. A good cat on a well tuned engine reduces HC just fine without AIR.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
