Cleaned IAC, High RPM solved
My rpm was high, to bring it down I had to tap on gas ( or tap it backward from behind the pedal). I got a throttle body cleaner, opened the it up and cleaned the IAC.
I had an IAC from a salvage yard, I cleaned that one and just replaced it with the one already there. It idled first time, but on the second start the car would not idle. I pulled the IAC and noticed the pintle was not retracted. I cleaned the original iac without pulling the pintle out, and put it back in. The car idles smoother and the rpm does not get stuck high.
I am not sure if it was the result of the clean iac or cleaning the throttle over all, I sprayed on the throttle where the kickdown wire is connected as well.
The write up for cleaining the iac says " open the throttle hose and clean the passage way". Is it the metal hose right on left side of the iac?
The idle was surging before the cleaning. It did some surging after the cleaing as well but it disappeared when I dorve the car around the block.
So what else to clean? Can I use the throttle cleaner to clean the injectors? How about MAP and MAF?
Re: Cleaned IAC, High RPM solved
89 Camaro L03
The high RPM is back. The engine has smoother idle tho. After driving around it usually surges one time at the stop light and then rpm stays stable around 600-700.
The high RPM is happening after Swap to T5. I think a double spring on throttle will resolve the issue.
I also got a manual Prom for that year and planning to put it on as well. It is a FED prom so I am expecting some improvement. Will post the results here.
I am wondering ....those of you with L03... does your engine run so smooth that sometimes you cant tell if its running at all? Like no shakes at all?
Guest
Posts: n/a
So your saying spray some iac cleaner in there it will fix becuse when i start my car the thing launches up to like 2000 rpms and i put it in drive to go down to 1000 but then it goes right back to 1900 or 1850 when put it in park??
Guest
Posts: n/a
I'm pretty sureit's the same on my car old thread getting back to was looking up how to clean it never had the time to think im going to do this tommorow but need to get spend five bucks put some gas inmy car as it sits.
Car: 1988 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 4TH. GEN. REAR
yup! My car does this samething.I think its normal. I just throw into gear and after it runs for a while, the rpm stays around 1000 in park/neutral.
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
cleaning the port where the IAC screws into the throttle body is important . i went through the same as above to no avail with a new IAC . removed IAC again , inspected , took a small insp. mirror , looked in port that IAC screws into . OMG , what a crud build-up . sprayed carb cleaner into port and cleaned it with a small rolled up piece of scotch brite . sprayed cleaner again till port was clean . re-installed all , problem solved . hope this hint helps , good luck . worked for me .
mdtoren
Aug 16, 2015 05:45 PM
