Air charge temp sensor?
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
When I bought my camaro, the previous owner had put an air cleaner on:
What sensors need to be moved or relocated? I know there are threads and how-to's on doing this but none of them really have pictures.My uncle tells me that I need an air charge sensor. The previous owner put a paperclip into one of the plugs to trick the computer, but I don't know what sensor SHOULD be there. You can see it circled in the picture above.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Air charge temp sensor?
It's probably the AIr temp sensor you need. you can cut a hole in th ebottom of the air cleaner to mount it there. If you have to pass smog you might needs the thermac, but im not sure where you are. Other than that that's the only sensor they had to mess with to put that air cleaner on.
I was thinking that, the air charge temperature sensor? What is this thing:
Is that the thermac? I'm in MA, and after the car is 15 years old, it doesn't need to pass smog/emissions.
Thats it. Thermac. It diverts air from ext manifold. Base of AC as stated is place to put IAT sensor. IAT sensor is is a 0-5V sensor. I ohm'd mine to see what would happen when it was new. I placed in freezer and as it warmed up sure enough resistance changed. I presume with paper clip in there no resistance. Not sure if that is a good idea. i doubt it is. cheap enough to buy.
SO I need an Intake Air Temperature Sensor and not and Air Charge Temperature Sensor?
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
//RF
Okay, I ordered one, do I need to make a hole in the air cleaner base, or is there a spot for it already? I never really looked at the base of it. I would right now, but my car isn't here where I live.
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
u can also relocated somewere in the engine bay, some ppl say its good to put it somewere were theres cooler air but i guess that does nothing, i drilled a hole the size of the sensor on my open element base and left it there, also if i were you i would buy an AC delete pulley and install it in place of the compressor there, the PO sure did a nice job removing the ac lol hey why remove the lines when u can just twist and cut them, i guess he just let all the freon out.
I"m not too sure why he did that haha Is it possible for me to reinstall the parts that he removed so that I can have AC again?
Car: 87 GTA
EDIT: I was looking at the wrong (the 2nd) pic.
That thing, the silver canister looking thing is missing. Not sure what it's called.
Engine: gone
Transmission: gone
Axle/Gears: gone
They call it the accumulator, or the reciever drier. If your system has been open it's best to flush it out. I would also replace the orifice tube, it'll be easier to flush w/o that in there.
Car: 75 Beast
I would look for a spot in the base of the air cleaner plate that is interference free. Most of these open element cleaners were designed for carburetor application - hence no provisions for IAT mount. You'll definitely need to check for interference before drilling a hole for IAT. As side note - these oversize air cleaners feed engine with hot, under-hood air. I would rather feed cold air instead.
//RF
//RF
//RF
Does anybody have a picture of this sensor installed in their air cleaner?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Check this out. There might be the info you want in there
http://snflupigus.tripod.com/tech/op...tep1/step1.htm
If that black thing pictured in the link above is the sensor I need, then I ordered the right thing. Thanks guys!
Engine: gone
Transmission: gone
Axle/Gears: gone
the orifice tube is inline in the a/c hose. your a/c hoses may have been cut or look like they are missing...check out the cooling thread for any a/c questions.
Well, after my uncle told me that I need an air charge temp sensor, and I have seen the same type of sensor being uses on another member's open air cleaner. Is this the right thing?
I can't remember what member is is who has it, or if they are even on this website, I may have gotten it confused. Anyway, is that it?
I am using a 1989 L03 IAT (camaro). It does not look like your photo. The tip is more like a small lipstick protruding for lack of a better word. First one they sold me(1992 L03) was a birdcage looking devise and it would not work.
db057
Aug 11, 2015 10:11 PM
