Dual Snorkel vs Open air element.
Old Apr 28, 2011 | 02:24 PM
Dimitrios123's Avatar
Car: 1989 IROC
Engine: 305 TBI
Pretty simple question, which one will net me more of a gain? Thank you in advance for insightful answers.
Old Apr 28, 2011 | 03:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Dual Snorkel vs Open air element.
It one of the Great Debates - been discussed, analyzed, and argued to death on here for many years. Pick one or the other, whatever you like - because there is no definitive answer for your question.
Old Apr 28, 2011 | 03:57 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
newbie is right lol but if this helps the dual snorkle looks cooler IMO
Old Apr 28, 2011 | 07:43 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
stock hood dual snorkel. if you have a cowl a open element...some sort of fabricated cold air induction is better yet..do a search and you'll see!
Old Apr 28, 2011 | 07:50 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I agree, the dual snorkel looks way cooler. And with it's flexible duct-like "arms," it makes me think of the robot on the original "Lost In Space" series... "DANGER!" lol
I'd guess most people already know the "arguments" about this topic, but I'm going to go through some ideas anyway, trying to maximize the best qualities of each intake, because each intake can have an advantage over the other, depending on the car(a Camaro or a Firebird) and the hood.
An open element under a non-functional stock hood will only be exposed to the hot environment under the hood, so it can't get fresh("cold") air. Whereas, the dual snorkel intake on a Camaro always draws fresh air through the openings above the headlights. So in that regard, the dual snorkel would appear to have an advantage over an open element. Further, since a Firebird has no openings to expose the snorkels to fresh air, a Camaro with a dual snorkel intake would even have an advantage over a Firebird with one.
But with functional hoods, such as an SS hood on a Camaro, a Super Duty hood on a Firebird(like an SS hood), a Cowl hood(open at the rear) on either car, and maybe even a stock Firebird hood with an open power bulge, then I think an open element would perform, at least, as well as a dual snorkel intake, maybe even better when the car is moving, because it would always be exposed to fresh air through the openings in the hoods.
And to make an open element even more effective with functional hoods, get a K&N XStream open element with the flow-through top. Then fresh air will always be drawn straight down into the carb/TB.
But this would be the monster "sucker," IMO:
A dual snorkel intake, a K&N XStream flow-through air cleaner lid(in place of the stock air cleaner's metal lid), and a functional hood.
On a Camaro, it would always-and-only be exposed to an unlimited supply of fresh "cold" air all the time, sucking air through its dual snorkels from above the headlights(as it's designed to do), AND it would also be exposed to massive amounts of fresh air through the top. All-in-all, it should provide more than enough air to support even the most powerfully-built engines, I'd think.
K&N makes an XStream lid for a stock GM air cleaner. It's chrome, but you could scuff it and paint it if chrome isn't your style, and it's an inch taller than a stock thirdgen's lid(because it's made for trucks). But it has the same "GM" diameter(15"-ish, I think). So you'd use a filter that's an inch taller than stock, which I think would be 3-1/4" tall(stock-size, I think, is 2-1/4" tall), and K&N has that too.
*Edit: I did this to an '89 TBI Firebird 'Vert I had a few years ago, so I know the taller K&N lid fits under a stock hood without any clearance issues(barely). I installed a Formula hood, opened-up the power bulge, adapted a dual snorkel air cleaner to fit the TBI engine, fit it with the TBI's IAT sensor(described in another current thread), and used the K&N XStream flow-through GM chrome lid on the L69 air cleaner, with a K&N 3-1/4" air filter inside. It provided a nice kick-in-the-pants, and it made the 5.0 engine sound BIG lol.
And to decorate the K&N XStream lid, either scuffed-and-painted or left chrome, you can get a NOS HO decal from Modern Day Muscle. Take your pick:
http://www.moderndaymuscle.com/inc/sdetail/172/779
http://www.moderndaymuscle.com/inc/sdetail/172/780
Last edited by LAFireboyd; Apr 28, 2011 at 09:02 PM. Reason: always editing for clarity lol.
Old Apr 28, 2011 | 08:13 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I had the gm lid on my air cleaner...it worked good. I went with a full xtreme setup so now it sticks up through the hood 2 inches
Old Apr 28, 2011 | 10:59 PM
mr305's Avatar
Car: 91' RS
Haha that's funny I always said they looked like robot arms too!
Old May 10, 2011 | 08:04 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i run both. i have a L69 setup and run a "too big" air cleaner so the lid is 2" or so above the air box. so its like a L69 setup and can also pull air from around the air cleaner. when on the high way i get the small ram air effect but at idle or at a light the open element definetly helps. i also used a flat bottom air cleaner and cut it and attached it to the l69 so i get straight airflow instead of the horrible oem setup.
Old May 11, 2011 | 12:38 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I think a full fledged cold air setup is better. Thier was a thread going around about the statitistic of ram air and reality. Basically it's not really happening. But if my car didnt have the cowl I would deffinately have a cold air kit. but with the cowl i go for the open air because it fits the car more. I do plan on making a cold air box to block out the engine compartment heat altogether.
Old May 15, 2011 | 07:26 PM
Car: 1989 IROC
Engine: 305 TBI
Ive been looking for a dual snorkel.......anyone know any sights that sell them??????
Old May 15, 2011 | 11:02 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
www.thirdgen.org check the for sale section sorry couldnt help it...these are desirable actually. the hard part is finding the ducting. Most people end up going with some aftermarket ducting stuff. Good luck. (put out a wanted ad in the wanted section here also)
Old May 16, 2011 | 07:08 PM
Car: 1989 IROC
Engine: 305 TBI
already did lol
Old May 16, 2011 | 09:33 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I just seen that. I always check the parts wanted at least once a week. Just saw yours. I'll keep my eye out too. Im always watching craigslist in my area.
Old May 17, 2011 | 08:31 PM
Car: 1989 IROC
Engine: 305 TBI
Hey btw completely off topic....is your only mod the gears to get that quarter mile time?
Old May 17, 2011 | 09:07 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
i have an open element and wish i didn't throw out the stock setup. they both make a different tone some like the sound of hearing the engine sucking air through an open element but i some what dislike it i always thought i had vacuum leak, i would get cold air intake so i could easily (someday) attach a wynjammer supercharger
Old May 17, 2011 | 11:00 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
With my Cowl hood I went with a 14x3in. open element with X-Stream filter top. As already said, it not only works well it fits that style car/hood design best. Whats the point of having a cowl hood without one. Now if I had a stock hood I would most likely have gone with a cold air kit of some sort.
Old May 17, 2011 | 11:44 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
nope not at all! check my vbgarage for the mods. I might not have updated recently though. Ill check into that
Engine: gone
Transmission: gone
Axle/Gears: gone
wynjammer supercharger now your talking
Brinkkl2000
Aug 4, 2018 08:29 AM
formula_novice
Sep 5, 2015 03:58 AM
BurlyChev
Aug 22, 2015 01:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
wruiz
Aug 13, 2015 09:07 PM
