tbi fuel pressure starts high and drops gradually
Car: 85 chevy k5
Engine: TBI 350 H.O.
Axle/Gears: 4.10
so i have retro fitted a tbi setup on a '85 chevy blazer, and am using an external adjustable fuel regulator. what's happening is the colder the motor temp is the higher the fuel pressure. as it warms up it drops till my setting of 14 psi. i need ideas why the fuel pressure starts high and then drops slowly as it warms up....
Car: check
Engine: check
Transmission: check
Re: tbi fuel pressure starts high and drops gradually
Liquid filled gauge under the hood? If so it is the gauge, not the fuel pressure. The liquid expands as it heats up and puts additional pressure on the Bourdon tube, thereby displaying a lower fuel pressure.
RBob.
RBob.
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah i have noticed mine does this too. ugh. i need a higher pressure pump anyway. according to my gauge im getting barely 10.5 lbs..
Car: 85 chevy k5
Axle/Gears: 4.10
i bet your absolutely right!!! liquid filled gauge and under the hood, yep. so when its hot and saying 14 psi, its probably less in reality? set the pressure when its cold and forget the gauge when its hot?
Engine: gone
Transmission: gone
Axle/Gears: gone
set when cold and forget when hot. And what he is saying is if its showing 14 its actually more
Car: check
Engine: check
Transmission: check
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
it has a pressure equalizing/liquid filling port.
Setting the pressure cold won't work either, remote mounted Bourdon tube or electronic transducers (I use both) will also show a drop, as the rise to normal operating temps affect pressure.
The solution is to NOT use an underhood gauge, liquid filled or otherwise.
Most Bourdon tube gauges state 140*F as an upper limit.
Check & set your fuel pressure at operating temp with the proper equipment.
A gauge like this will correctly reflect the warm pressure drop.
http://www.amazon.com/Actron-CP7817-.../dp/B0006V2BK0
Electronic gauge & sender can cost $200.
Shop around for the best price/equipment to suit your needs.
92camaroJoe
Aug 13, 2015 06:07 AM
