L31's on my 305
Old Aug 19, 2011 | 05:48 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 2.73 installing the 3.73 soon =D
L31's on my 305
Okay, so I have seen multiple posts on this topic but none really answer all my questions, one of my biggest questions is can I run the stock 350 tbi vortec intake manifold on my engine with those heads? And also on a little bit of a different note how much horsepower would I see if I used the 305 vortecs instead?
Thanks in advance!
Old Aug 19, 2011 | 05:53 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
And how would it run if I were to put them on my engine with a thin head gasket and just left the stock cam in?
Old Aug 19, 2011 | 06:36 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: L31's on my 305
yes you can but you will need to shave them down about 30 thousands to keep up the compression. should throw in an lt1 cam in it while you have it down that far. it will run descent. then get a tune and do the tbi mods with an open element. do an exhaust to.
Old Aug 19, 2011 | 09:20 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
I already have an exhaust done, I still have the open element on my list of things to do lol, but with the lt1 cam, will the springs and everything be okay with that lt1 cam in the vortecs, and should I replace my lifters or push rods? Or will my stock ones be suffice?
Old Aug 20, 2011 | 08:20 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: L31's on my 305
you should be ok with the lt1 cam. but the springs are not much for a piece of mind.
Old Aug 20, 2011 | 10:13 AM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
With the heads down should I still use the thin gaskets? And about what compression will I be at, and the shaving doesn't affect power output correct? Thank you again
Old Aug 20, 2011 | 05:07 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: L31's on my 305
the combustion chamber is bigger on the l31 heads. if you dont shave them you will be lower compression which will result in loss of power.
Old Aug 20, 2011 | 06:02 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
So what size gasket should I use?
Old Aug 20, 2011 | 06:49 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: L31's on my 305
YOU NEED TO SHAVE THE HEADS. THEN USE THE STANDARD GASKET.!!!! PERIOD. then work from there.
Old Aug 20, 2011 | 07:04 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
Okay, no need to go all caps rage on me you just never clarified that part.
Old Aug 21, 2011 | 04:10 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: L31's on my 305
A thin head gasket to keep quench as close as possible to 0.040 in would be best.
Stock piston to deck of the LO3 should be around 0.025-0.035 in, a thin gasket like the Fel-pro 1094 http://www.summitracing.com/parts/FEL-1094/ should be ok for sealing a undecked block.
I would skip the whole milling the 350 heads and get a set of 305 heads instead.
Old Aug 21, 2011 | 04:50 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: L31's on my 305
Yes skip the milling all togather and get a set of 059 L30 heads.
Old Aug 21, 2011 | 05:19 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
Well I already have the l31's =\, so mill them or thin gasket? Which is the better course of action? Thanks
Old Aug 21, 2011 | 05:24 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
if its safer just to mill them, I'll stick with that, which would make it run "safer"?
Old Aug 21, 2011 | 06:19 PM
thomas1976's Avatar
Car: 91 Trans am
Re: L31's on my 305
Need to be milled to avoid a disasterous CR.
The thin head gasket is required to avoid a bad quench.
Not sure how reliable the 350 heads will be, once milled to obtain 56cc combustion chamber or less (56cc for around 9.25:1 CR).
There are plenty of online calculators, should start playing with them at least a little.
Old Aug 21, 2011 | 06:25 PM
thomas1976's Avatar
Car: 91 Trans am
Re: L31's on my 305
I would save up a little and go with these instead http://www.summitracing.com/parts/TFS-30300005/
Old Aug 25, 2011 | 07:25 AM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
Well, I wanted to just say this, after much thought, I am thinking converting to a 350 tbi would be a better idea and just getting the heads redone, figured I'd give everyone a heads up, I'm sure I will be back on the site with more questions at a later date, but Thanks to everyone who helped here!! =D
Old Aug 25, 2011 | 12:27 PM
thomas1976's Avatar
Car: 91 Trans am
Re: L31's on my 305
350 ci is a good choice , now I'm courious why you would not use the L31 heads on it.
Old Aug 25, 2011 | 01:05 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Re: L31's on my 305
Oh, I meant I'm gonna redo the vortecs and put them on the 350 with a gmpp vortec tbi intake manifold and do a mild cam :P
Old Aug 25, 2011 | 01:20 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Re: L31's on my 305
I'm actually looking into this myself. Since I have another LO3 laying around, and don't want to spend too much money, but on the other hand the LS1 conversion will take me probably at least a year to save up for and shop around for parts (ie Ford 9 rear end, all the wiring, LS1 fuel tank, gauges, transmission, the engine)
So the 062 or 906 heads, can one use a gasket for a 305 or does it need to be the 350 gasket ?
Also on another note, can one pass smog with EGR if one converts to the MAF TBI PCM ?
Old Aug 26, 2011 | 02:11 PM
thomas1976's Avatar
Car: 91 Trans am
Re: L31's on my 305
Sounds resonable
Old Feb 13, 2013 | 08:33 PM
GaSS burner's Avatar
Car: 91 rs camaro
Engine: l31 swap
Axle/Gears: 2.7
Re: L31's on my 305
I know nobody has posted on this in awhile but i got some awnsers. vorgath. you have to use a 350 head gasket did this swap awhile ago and it was one of the issues that came up. meis Travis you have to use milled heads and use a thin head gasket. but doing the actual l31 swap is all together better. dont get that TBI vortec intake its junk compared to the edlebroock performer RPM thats made to fit up with the vortec head. that intake bolt pattern sucks of course. put a nice cam in there while your at it. the 305 peanut cam just use it for show peice. since you wanna go TBI you going to need to emulate your computer for a really nice tune. you can get over 300 hp from this swap.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
