TBI on a 1980 305 block that had a carb
Old Nov 20, 2011 | 10:09 AM
camaro1992ttop's Avatar
I had a 305 tbi in my 1992 rs but it has 3 dead cylinders so I found a smoking deal on I think around 1980 new rebuilt 305 long block that is carb intake setup. I was looking at some forms and they said I can drill the center holes carefully at a angle to put on my old tbi intake can anyone give me some input on this Thanks.
Old Nov 20, 2011 | 12:06 PM
ex-x-fire's Avatar
Re: TBI on a 1980 305 block that had a carb
Its more of slotting the holes & grinding that area so the bolts sit flat. You might have to use larger washers too.
I think you might have to change the distributor gear over, the 92 engine should have a bronze gear to match a factory roller cam. The older engine probably has a regular flat tappet cam, so it needs a steel gear.
Old Nov 20, 2011 | 12:48 PM
Thank You I still have about another week or so till the intake install if anyone else has any more input let me know
Old Nov 25, 2011 | 07:30 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
you will also need a different flexplate for the two piece rear seal crank, and a blocker plate for the fuel pump port.
Old Nov 25, 2011 | 07:34 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
also if it doesn't come with valve covers the older heads need perimeter bolt covers.
Old Nov 25, 2011 | 07:38 PM
Damon's Avatar
Your original TBI heads will bolt right up to the 1980 block (and they have the same 58cc chamber size as the 1980 vintage heads). Of course, if the reason you have 3 dead cylinders is because your TBI heads are shot..... that swap wouldn't help much. Used stock LO3 heads in good condition can be found for about zero bucks, fortunately, for someone willing to pick them up and haul them away!
Yes, you can modify the intake manifold but it will always be a bit of a "hack job" since it's not just the angle of the holes it's also the angle of the pad that the bolt heads seat against.
Old Nov 25, 2011 | 07:45 PM
one92rs's Avatar
Car: SOLD!!!!!
many that have done carb swaps on the 87 to 1992 engines including me have slooted the center bolt holes on the intakes and had them work fine. they will seal great. no worries.
Old Nov 25, 2011 | 07:58 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
word. i've done it as well.
Old Nov 25, 2011 | 08:12 PM
Damon's Avatar
Yes, but you went the other way. Carb intake onto TBI heads. He would be doing the opposite.
Old Nov 26, 2011 | 04:15 PM
one92rs's Avatar
Car: SOLD!!!!!
put a carb intake on it with an adaptor if he has to. if he is using tbi heads it wont be a problem. either way it is easy to make it all work.
Jake_92RS
Jan 28, 2020 10:37 PM
pimp2303
Jul 27, 2017 02:03 PM
theshackle
Mar 5, 2017 06:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
theurge
Aug 21, 2015 12:46 PM
