Stiff gas pedal
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Stiff gas pedal
Im not sure if this is in the right category but does anybody else have a very hard ga pedal, not sure if rhi just a general third gen problem or a LO3 problem, it makes it hard to drive smoothly?
Re: Stiff gas pedal
did you remove the tbi at all or remove and reinstall the tbi throttle cable,. if you put the cable on the wrong deal it will be hard. once you put it on the right part it is easy.
throttle cable--top inside
cruise control--top outside
tv cable--bottom outside.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Stiff gas pedal
if the cable was kinked it would cause this. Did it happen all of the sudden or after working on the car? or did you just recently get the car?
Engine: 305 LO3
Re: Stiff gas pedal
I got the car last April and drive it all summer with the stiff pedal, it's a challenge, If I'm at a red light it's impossible to slow ease on the throttle it's that stiff. I have to give it a quick tap to loosen it up then I can ease on it
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: Stiff gas pedal
When I first got my car the po had a return spring on the throttle body that made the gas pedal pretty stiff. You should take the air cleaner off and have a look at the throttle body.
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
Re: Stiff gas pedal
Mines been somewhat stiff too as long as Ive had my car (about 7 years now I believe). Never really found out what caused it though.
Car: 89 camaro rs
Engine: 350 LT1
Transmission: 4l60
Axle/Gears: 3.42 or so.
Re: Stiff gas pedal
So i think that i've got the same problem....my pedal sticks closed and it feels like it's stiff. i have replaced my throttle body and it still didn't change anything. i was kind of curious if there was some warping in the intake manifold would the throttle body twist and hold the throttle plates closed or make them stiff? when i tighten down the throttle body they stick worse, but when i leave all of the bolts finger tight it's almost gone. Also something else i was thinking was that because our cars are so old that if the idle screw has been adjusted to bring the throttle down any that there is a groove worn in the throttle body and the throttle plates are sticking at that grove. Is there anyone who can confirm or deny any of what i'm thinking?
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
Re: Stiff gas pedal
My gas pedal is kind of sticky too, ive gotten used to it..but a lot people say it could be carbon buildup on the throttle plates
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Stiff gas pedal
WD 40 on throttle cable and oiled up under the dash makes it smoother. Must eliminate that friction with lube!!
Can pull the 3 cables off and see if they have abnormal resistance as well!!
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 4th gen posi 3.43
Re: Stiff gas pedal
Hello, thought i would post in here instead of starting a new thread. I have a 92 rs 305 tbi and i was wondering what would cause the gas pedal to be stiff only while the car is running? it feels nice and smooth with the engine off but after you start the car it stiffens up dramatically. Thanks for the help.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Stiff gas pedal
As long as your springs are on the butterfly shaft and your accelerator linkage is easy moving, there shouldn't be any reason why it feels any different when running or not
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Re: Stiff gas pedal
Thats what i thought to, It's very strange but i just confirmed it a few mins ago got in the car before starting pushed gas pedal and it felt nice and smooth like it should, started car and it immediately stiffened right up its the most stiff when you first push the pedal down and gets kinda easier the closer you get to the floor but still fairly stiff all the way through but mostly when you first press the pedal its extremely stiff.
Car: check
Engine: check
Transmission: check
Re: Stiff gas pedal
If no change, or if a stick shift, then likely the throttle shaft and throttle shaft bores are worn.
RBob.
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Re: Stiff gas pedal
Thanks for the reply RBob the car is a t5 manual trans and the only cable to the tb is the throttle. So you suspect that the shaft and bores are worn out? Does that mean i need to find a new tb?
Car: check
Engine: check
Transmission: check
Re: Stiff gas pedal
The shaft bores can be drilled out and bushed. Doing so usually allows a slightly worn shaft to be used.
You may be able to crutch it by opening the throttle blades a little. This is done via the idle stop screw. Should use a scan tool while doing this and aim for 5 - 10 steps on a warm engine with no other loads (A/C off, fan off, ...).
That can work if the blades shift from the wear and are locking up on the bore wall. Besides, TBI set ups work better with the lower IAC steps at idle.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Re: Stiff gas pedal
Yes, it is removable. IIRC, I would use a sharp punch or a finishing nail to put a hole in it, then twist and pry it out.
The idle stop screw is Torx, so I remove it and cut a slot in the head to use a regular screwdriver.
RBob.
RBob.
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Re: Stiff gas pedal
Ok great, thanks a bunch for your help. Also forgive my ignorance but what kind of scan tool do I need to make the adjustment?
Also, so I just drive a finishing nail anywhere into the plug and pry till it comes out?
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Re: Stiff gas pedal
I also noticed someone had said the cable needs to be connected to the throttle body on the top inside point but my throttle body only has provisions for an outside connection. Don't know if this has anything to do with it or not but thought it was worth mentioning.
Car: check
Engine: check
Transmission: check
Re: Stiff gas pedal
An OBD1 handheld scan tool can also be used.
The plug is thin sheet metal.
RBob.
Re: Stiff gas pedal
Re: Stiff gas pedal
If you disconnect the throttle cable and remove spring the slop in the shaft can be determined by wiggling the shaft.
any carb shop can handle it and I believe they put in a quality bushing. Or you can mail it out. I think DCTrumpet here offers bushing service?
i forget if original GM TB even has bushing? I put a new TB unit on my car and it was silky smooth. My cable has 124K miles on it and still smooth.
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:17 AM
