tbi cam help
Old Mar 29, 2012 | 08:32 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
tbi cam help
i have been building a 355 tbi (with ebl flash) for my car and i have been looking in to a new cam for it but i have been told that you have to have a high lsa for the motor to run good and reading some of the other threads on here i have come to understand that you have to have a high lsa and small duration for the tunning to be easy although im assuming theres more to it than that plus i used comp cams cam quest and it shows all the cams with high lsa and low duration eather havte a really low power band or dont make any power at all im trying to fined a cam that will give the car a mid to high power band the heads are 906 vortec heads with the comp cam version of the ls6 springs witch give the heads a max lift of 550 so if any one could give me some cam recomendations or just help give me some more imfo. on how the cam dur. lift and lsa play in to the intake vacume and the power band of the motor that would be great thanks for the help
Old Mar 29, 2012 | 09:55 PM
kill4thril's Avatar
Engine: 355ci
Re: tbi cam help
i have been looking at these two cams but the one with the 110 lsa is the one i like more but i was told it would be a nightmare to tune ? http://www.summitracing.com/parts/CCA-08-503-8/
http://www.summitracing.com/parts/CCA-08-423-8/
Old Mar 30, 2012 | 11:26 AM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: tbi cam help
The 08-503-8 cam is a good choice to maximize hp from the vortecs. That combo should be capable of over 400fwhp.
Yes, it will present somewhat of a challenge to tune, but do-able. EBL will make it somewhat easier. The more cam overlap the more difficult the tune. Could go with a comp cam in the 262-268 range, but that will lower your rpm range and loose some high end hp. All depends on what you want.
Old Mar 30, 2012 | 11:37 AM
Ronny's Avatar
Re: tbi cam help
I chose a 12-268-4 224/230 @ .05 with a 114 LSA 1800-5800 rpms. that RPM is spot on. Power falls off at 1700 during cruise under load 5th gear @ 60 mph.
Another choice would be one step down on duration (220-226?) but 112 LSA peaking around 5400.
Old Apr 17, 2012 | 11:55 AM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
Re: tbi cam help
i have a 350 bord 30 over with trw pistons and scat crank i wanna keep my tbi .Now when i have this motor built im sticking a lt1 cam in there how much power will i get out of it im puting headders on the motor to i have a ful 3 inch flowmaster system on it now the heads are the tbi head with port and polish and 525 lift valve springs i just want 300 hp to the tires can i make that goal with bored out tbi and bored out intake and chip
Old Apr 17, 2012 | 02:26 PM
Ronny's Avatar
Re: tbi cam help
Unlikely...
Old Apr 17, 2012 | 05:59 PM
Re: tbi cam help
why unlikely tho is the cam not good enough for the motor or is it the tbi 350 heads with new valve springs and lt1 cam.Should i get a different cam im not rich so i cant get vortec heads right now at least well i be close to 300 hp at all or am i gonna have a ton of tq right now my 305 tbi dynos 202 hp and 268 tq i better have a lot more hp and tq on a 355
Old Apr 18, 2012 | 10:24 AM
Ronny's Avatar
Re: tbi cam help
can i make that goal with bored out tbi and bored out intake and chip?
Just my opinion. I would do a search for members that have posted mods and dyno results. A good search is for member Fast 355/Fast305 as he has posted his combos and dyno results I recall.
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
