LT1 HELP!!!!!!!!!
Old May 11, 2012 | 06:35 AM
Rondeezzee310's Avatar
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
LT1 HELP!!!!!!!!!
Just found a lt1 for $250 bucks because the 305 just isnt cutting it. Im sure my question has been asked b4 but in separate topics but i want a full understanding on what im thinking ill need.Please bare with me.
1.the lt1 i found has the fuel injection on it but all i want is the motor.
QUESTION 1. Will my atl, power steering brackets, ac smog pump, distributer, bolt onto it.[i have a serpentine setup]
2. i want to keep my tbi unit for the[ sleeper look ] what size injectors do i need to switch to? serial numbers please.
3. What intake manifold do i need?serial numbers please.
4. I have my stock ecm so what style chip do i need? serial number please.[i hear people talk about ebl flash but what to do in the mean time]
Old May 11, 2012 | 10:03 AM
Ronny's Avatar
Re: LT1 HELP!!!!!!!!!
http://forums.corvetteforum.com/c4-t...onversion.html
Old May 11, 2012 | 10:25 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
While I thank you Ronny I don't have a Corvette I have a 1991 camaro. I don't want to try an understand what they did I need to know we did for a successful in stall.
Old May 11, 2012 | 10:32 AM
Ronny's Avatar
1984 was TBI. My 1984 is running FBody TBI not Vette TBI. So Vette is very similar to F Body as is TBI Truck. Same on ECU. Similar throughout.
There are few that would attempt it. Much like dropping a LS in a FBody. Expensive and complicated unless you are a pro mechanic and have the $1,000's of bucks to do it.
Granted you could go to salvage yard but some stuff will need fabricating.
I would search this site for others that attemted or had desire to do so. Also search Corvette Forum for the TBI to LT1-4 conversion details.
I found this https://www.thirdgen.org/forums/ltx-...otor-wont.html
Old May 11, 2012 | 11:09 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Ok ill check it out I just don't want any issues to pop up so I like to only deal with camaro questions not similar issues but ill check it real quick. I want to stick with the basic LT1 people seem to start throwing all sorts of ideas on what to do.
I have a basic lt1 I want to put in. Once its in I can starting changing things so keep it simple.
Old May 11, 2012 | 11:47 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
That didn't tell me anything. I just want info from camaro people about there camaro build. I Have four questions please no more no less. Threads have a tendency to drift to million different issues so I just want to keep it straight to the point an not get confused.( all I have is the block No harness No ecm for the lt1 No intake. JUST THE BLOCK
Old May 11, 2012 | 11:00 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
There's no point in buying just the block of an LT1, unless you're completely rebuilding it which it doesn't sound like you're doing
Old May 11, 2012 | 11:24 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i think he means he has the"long block"assembly-good
deal for $250 if its halfway decent shape will have to
make up custom accesory drive or adapt early 4th gen
accesory drives...
I googled"carbed '90s LT1"and found all kinds of info on
carb (and therefore TBI)and standard distributor usage
with these engines.
Old May 11, 2012 | 11:35 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Thats gonna be the first thing I do is real build it then ill put it in. I'm not trying to have supersonic speed just more than my 305. I just want to know if ill need anything else for the swap. Cuzz I have taken parts off my 305 an put it on a 350 that ran fine. But I havnt dealt with a lt1 yet. I just want to have everything I need when I drop it off next week..
Old May 11, 2012 | 11:44 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
8tzchen I was looking at the picture of the motor an it has all the assembly brackets an alt.Water pump.intake basically eveything .... it has the harness .so if it has the brackets can I use my old alt, waterpump ...on the lt1. Also if I find a ecm for the lt1 will it effect my dash gauges or do I have aa electic shop put the two harnesses together.
Old May 11, 2012 | 11:50 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
At this point I just wanna know the easiest way to get this motor in. SO basically its picture a lt1 sitting on the floor with your tbi camaro next to it an you want to know how to get that motor in that car.lol
Old May 12, 2012 | 12:09 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Heres the motor I called to see if he had the computer but he hasn't hit me back yet.
Old May 12, 2012 | 10:03 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Looks like a '94-97 f-body LT1,'93s had different
alternator and 'vettes had different accesories.
the LT1 had a special reverse flow cooling system and
gear-driven water pump(driven by gear teeth on front
of timing sprocket)TBI ECM cannot operate the LT1s
"optispark"distributor,so you will need to adapt a 94-97
LT1 ecm into the car if you do complete LT1 swap.
LT1 block still has hole for standard dizzy,so with that
,a correct intake manifold and the cooling system
adapted,you could run a TBI on it
Old May 12, 2012 | 07:28 PM
morgsie's Avatar
Good luck using your old water pump on the LT1.
Old May 12, 2012 | 08:50 PM
platynumx's Avatar
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
Why would u dumb down an lt1 by putting a tbi on it? If u want a sleeper look put a "tune port injection" plaque on the lt1s throttle body and say the optispark is a race ignition setup(lol). I don't get the whole sleeper thing honestly.if I put an lt1 in my car I would want the world to know.
Old May 12, 2012 | 09:07 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Platy that's cool for you but I don't want the attention. Its mainly for smog sir I can't go to a smog station with a tbi car with a tpi on it. Los Angeles has the weather but on the bad side it has smog requirements. I found the thread I was looking for so this thread is considered over.
Old May 12, 2012 | 09:12 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
But I do appreciate the positive feed back I've gotten so far.
Old May 12, 2012 | 09:20 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Thank z chev so your saying Imma need to find a ecm for the motor.
Old May 12, 2012 | 10:02 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
if you run it as a complete LT1 you will need an LT ECM
but if you adapt TBI and a standard intake manifold
mounted distributor to the LT1 long block,you could
run it with the TBI ecm(custom tuning might be
needed for best results)Have you decided/found out
what to do about the cooling system and belt-driven
accesories?AFAIK,LT1 can only use the gear driven
waterpump and a standard belt driven one will not fit.
Old May 12, 2012 | 10:16 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Z chev honestly with all this info I'm finding out I really think its not worth my time an money on a lt1 swap. Today I called afew engine shop an they were saying I could get a 350 roller motor and 0.30 over an use flat top piston an get numbers of about 320 horses or so. All I really want is a motor rated in that area so once I do my bolt ons I should be better off in horsepower. As you can see I have 22"are rims so racing every car on the street is out I just wanna beat 3rdgens an afew fourth an fifth ones. The feeling you get when u pass a new car is so wonderful I feel like a kids in a candy store.
Old May 12, 2012 | 10:19 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
??? V chev if I put a shift kit in will the change my overdrive. Somebody told me it might happen cuzz with these 373 gears my freeway would be annoying
Old May 12, 2012 | 10:24 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Just remembered certain '94-96 full size cars came with
a "baby LT1",4.8L IIRC-i don't know if those have same
accesory drive as f-bods,some of those cars with LT1
style engines and heavy duty cooling option had a belt-
driven clutch fan off to the side of the gear-driven W/P
Old May 12, 2012 | 10:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
yeah,would be easier to use a standard block instead of
converting the LT1(easier disguise for the smog police
too) LT1s are a cool engine though,would be cool to
swap that in if you could
Old May 12, 2012 | 10:35 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
I read that also so that added another wrench in buying it. The owner had no idea so I changed my mind.
Old May 12, 2012 | 11:29 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Lt1 have better cooling so I wanted to try it also. Z chev did you read my reply on shift kits?
Old May 13, 2012 | 12:22 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
shift kit won't change the rpm-ratios remain the same,
shift kit only changes shift firmness and when the shift
occurs. 3.73 gears are a little deep with a 700r4,could
swap those for 3.42 or 3.23 to make 1st more usable
and lower the overdrive cruise RPM-i like my 3.42s
with my torque-biased engine.
Idea with the LT1's reverse flow cooling was the heads
would run cooler to reduce chance of detonation,while
the cylinder bores would run hotter so the oil film
viscosity would be lower-reducing friction and wear.
In the mid 1980s, reverse flow cooling was something
engineers were really looking into-and GM adapted
the idea for the LT1,going back to standard coolant
flow for the all new LS design
Old May 13, 2012 | 12:57 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Gotcha thanks for the info
Old May 13, 2012 | 04:44 PM
platynumx's Avatar
Obviously I don't know if this is true or not since I don't live in ca but I was always told u can swap motors out there as long as the motor was same year or newer,same vehicle class(truck,car,hd truck,etc..)and all emission equipment it was fine and legal as long as it got recertified (or w/e its called by the smog policeout there),could pass both visual and tailpipe tests,and the donor ecm was running it and the ses light worked.
Old May 13, 2012 | 04:59 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
bra bra that is so true but remember "I HAVE A TBI NOT A TPI" its not a issue about the actual block. Well you come down here and do it and then go to a highway patrol station and see what they do.
Old May 13, 2012 | 05:47 PM
platynumx's Avatar
Ok you ve lost me somewhere.other than the "sleeper" aspect what is ur reasoning? Ur pic of ur motor is complete.seem like all u need is an ecm and a wiring harness.and recertification(w/e that means). Why don't u give a ring to ur local smog authorities and ask about motor swaps and what u need to do instead of tbi'ing an lt1 and trying to pull a fast one on an inspector that more than likely wont work.
edit also keep in mind the off the shelf intake for a carb(which u ll need with a Tbi adapter)is a gm performance part with no provision for egr.
Old May 13, 2012 | 07:20 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Thanks but nit that big a deal Imma go the route the engine shop said by just putting a 350 block with the flat top pistons, 0.30 roller everything an add some Bolt on's an enjoy what I get cuzz I'm sure its waywaywayway then this 305. Platy stop coming across so sarcastic. You may no alot but there's ways to say it bro. Thirdgens Up everyone else down that's my moto
Old May 13, 2012 | 07:34 PM
platynumx's Avatar
Wasn't trying to come across sarcastic...just kind of heads upish...but yea anythings better thn a 305 lol
Old May 13, 2012 | 07:41 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Platy questions for you. How do you make a 355 block.
Old May 13, 2012 | 08:49 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
To make a 355, you just take a 350 block, and bore the cylinders .030 over, and keep the stock 3.480 stroke, so you'd only HAVE to buy new pistons 4.030" for size (.030" over) but if you're going to buy rods and a new crank with it, you're better off getting the 383 kit, which still has the .030 larger bores, just a longer stroke, and for basically the same price
Old May 13, 2012 | 09:07 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
So basically if you're doing a full rebuild, you'd get more for your money with a 383, but if you just want to go with a 355, make sure you get flat top pistons so you get higher compression, thats where you'll see most of the gain, not as much with the 5 extra cubes
Old May 13, 2012 | 10:54 PM
platynumx's Avatar
find the cheapest place that does that.theres ur 355.u ll want (cant think of the rating right now)injectors off a (88-93iirc)350 caprice cop car and a chip burnt for ur stock ecm after u figure out what cam ur gonna run headers etc..
Old May 14, 2012 | 01:37 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
say fellaz quick question i was just thinking of weather there was a way to do some sort of 383 swap that doesnt have that idle. i would like tgo put a 383 but the way the engine idles will give me away. so i guest my question is can i use the 383 crank but use a cam that doesnt idle as rough but still get nearly as much hp an torque?
Old May 14, 2012 | 06:50 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Yes, you can get a cam that'll idle like its a stock engine, go to comp cams and fill out the cam recommendation form, make sure you let then know you want a smooth, stock-like idle, they'll then recommend you a cam and give you the specs of it, you don't have to chose the one they give you but base your cam choice off of that ones specs
Old May 14, 2012 | 04:48 PM
platynumx's Avatar
If u go with a "stockish idle" cam,u might not want to run those caprice injectors and just run truck tbi350 injectors.they re way cheaper anyways.iirc the caprice injectors were $200/injector new at advance auto.something like 60/injector for the truck ones.
Old May 14, 2012 | 09:29 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Cool thanx bro I was thinking that when you replied about the injectors. Do I need to say a certain year
Old May 14, 2012 | 10:50 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Now when you say burn a chip for the ecm. I hear people say buy a separate chip an some people say they plug some sort of device in and program your upgrades in but I think that's for newer models. Do you know the type of chip I need to buy an how to program it.
Old May 14, 2012 | 10:53 PM
  #42
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Say platynum. What type of chip do I buy an how do I burn it.
Old May 15, 2012 | 01:10 PM
  #43
platynumx's Avatar
I would recommend an osterich chip emulator.u can make "on the fly" changes to ur ecm with a laptop.then find a 305 tbi bin file to start with and adjust things accordingly.as for year of injectors,the ones I m running are for an 88 1500 iirc w/350(w/e my gf's friends husbands truck is). U might also want to look for the ultimate mod tbi stuff.
Old May 15, 2012 | 02:02 PM
  #44
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Nope
Double Nope
Use the factory EFI LT1 intake, or go carbed.
Triple nope. not worth the trouble of the conversion
Read the sticky, do the swap in full with EFI. Or get a carbed LT1 intake and run a carb.
From the way you describe wanting things you'll have a 10x easier job if you simply pickup a vortec 350, or some other SBC 350 engine and swap that in.
Old May 15, 2012 | 08:46 PM
  #45
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Thanx fellas I see I have alot of homework to do. Oh yeah will that ecm upgrade take the governor away.when I bought the rs I didn't know they were governed so when I changed my Rearend I hit the rev limiter I was told to things. 1. I could buy a ebl flash or2. I could change so sort of gear in the transmission to accommodate the gears change
Old May 16, 2012 | 09:10 AM
  #46
Ronny's Avatar
Yes. Mine is set to 6200 rpms on engine and 6000 on spray.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
