Whipple supercharger tuned chip available?
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Gentlemen, and I use that term loosely, haha,
I'm considering a 305-350 swap, retaining the TBI, using a 670, but with a used Whipple '88-'95 supercharger.
Do you know of any competent mail chip tuners/burners you could recommend for this combination beyond TBIchips?
I wouldn't be able to do the EBL data logging self tuning thing, unfortunately.
With the proper supplied mild engine specs, would this be do-able through the mail do you think?
Thanks very much.
Thanks very much.
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Re: Whipple supercharger tuned chip available?
I found this site a while ago. They offer a full procharger package for a 305 tbi. http://www.tbi-superchargers.com/TBI...o_305_TBI.html
to mod or admin: If this is against the rules or some stuff to post the link ill remove it.
Engine: 305 TBI
Axle/Gears: 3:08
Well, thanks for the input.
Sorry for the double post--hit the wrong key.
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Save your $$$ for the EBL purchase. It can handle boost.
Engine: 305 TBI
Axle/Gears: 3:08
Ronny,
I've seen endless tortured back and forth posts trying to dial in a non-factory TBI combinations.
Do you have any non-stock EBL TBI tunes under your belt that you think turned out well? I remember seeing your name here quite a bit. I mean for a carb only EFI newbie, would the learning curve be pretty long before it's drive-able?
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
if you plan on supercharging your tbi you will need more than just a way to tune it and just putting it on your motor. You will also need to use larger injectors and a higher flowing fuel pump to feed the motor. Adjustable fuel pressure regulator or vrfpr. Wideband o2 sensor is also highly recommended.
I point out some of these things because it helps to have everything covered before you begin installing the supercharger and to know what you are getting into. I have a wynjammer installed on my tbi along with the ebl and it still took some work and aggrivation to get it running half way decent and it still was not nearly perfect. Without the ebl or a way to tune it and datalog, you will have a nearly impossible time getting it to run right.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Look at it this way, would you rather have a car that makes 300 hp and gets 30 mpg or a car that makes 300 hp and gets 10 mpg?
A mail order chip would be ok for starting, but you couldn't drive the car over 2k rpms without breaking something, you would NEED to have it dyno tuned.
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
The first sentence was a reply to you, the second to the OP. Because you said that it is the same because it functions the same, when that isn't true. One is more efficient than the other, making quite a big difference in the two actually.
ramicio
Sep 28, 2015 01:18 PM
305, 8895, aupercharger, body, camaro, chip, gen, installation, instructions, iroc, specs, supercharger, tbi, throttle, whipple
