ECM swap question
Car: 88 Camaro SC
Axle/Gears: 3.42 POSI
ECM swap question
First things first, my car is an 88 camaro that came stock with the LO3.
Alright, so I've done your standard 305-350 tbi swap. As suggested in the 305-350 swap guide, I've ordered a 350 knock sensor to install (10456288) and injectors. My question is this: My camaro is an 88, meaning it has the 063 ECM. In the 305-350 guide I saw Fast355 said that the 746 ECM is a pin for pin replacement for the 063. Does this mean I could unplug my ecm, plug in the 746 and be good to go? I know a need a chip from a 350 car (such as the caprice).
My next issue is that I have a T-5, and I know no 350 cars with a 746 came with a 5-speed. So could I get by with a chip from a caprice and just deal with not having the shift light and a constant SES light until I get into chip burning?
Thanks in advance
Thanks in advance
Car: 88 Camaro SC
Re: ECM swap question
Exactly. I just don't have the time to dedicate to learning how to burn chips right now. It was my understanding that if I pulled a caprice chip, it would only work in the 746 ECM. Is that incorrect?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
no I think just $4D mask will work with the 1228063. you should switch to a 1228746 if you are going to stay with tbi instead of a odd ball ecm.
