ecm choice
Old Sep 6, 2012 | 09:36 PM
AvantiHall's Avatar
Car: 64 Studebaker Avanti,67 ElCaminoTBI
Engine: GM 350 10.5:1 Supercharged
Axle/Gears: 3.54 posi
ecm choice
Which system or computer is better, 89 chev truck 5.0 tbi computer 1227747 or 89 pontiac 5.0 tbi computer 1228746?
Old Sep 6, 2012 | 10:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ecm choice
better in what aspect ? code ?
Old Sep 6, 2012 | 10:54 PM
AvantiHall's Avatar
Re: ecm choice
I'm setting up a 1967 el camino, and I have the tbi parts and both ecms, only differance I see in the wiring is the pontiac has 2 ground driver wires for each injector and a mat sensor. Better in reliabilty and milage for the 327ci
Old Sep 6, 2012 | 11:03 PM
Engine: Lb9
Transmission: M20
Re: ecm choice
I would go for the 746 and start with a anlu tune. both are reliable ecms but the sa tables and the mat use is imo better.
Old Sep 6, 2012 | 11:42 PM
AvantiHall's Avatar
Re: ecm choice
Old Sep 7, 2012 | 02:58 PM
Ronny's Avatar
Re: ecm choice
8746 uses IAT sensor 7747 not.
Old Sep 7, 2012 | 09:00 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
Re: ecm choice
Personally I'd get a 7427 from a 94-95 1500 truck, they also came in Astro vans and I think S-10's. The data logging is so much better because it's 8192 baud and the PCM runs the engine so much smoother vs the C3 ECM's. Also no need to solder the pins together on the chip or run an adapter when tuning, just solder a DIP socket in place of the original chip and stick a ZIF socket in it for tuning purposes. If you already have a wiring harness for one of the older computers the connectors that plug into the computer will need to be repined to the 7427 connectors but it's fairly simple and takes about 45 minutes to do.
Old Sep 8, 2012 | 09:58 PM
AvantiHall's Avatar
Re: ecm choice
thanks, doing the 1228746, already have it, and harness for $00.00.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
gixxer92
May 18, 2017 11:20 AM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
