running very rich
Old Feb 10, 2013 | 04:17 PM
GaSS burner's Avatar
Car: 91 rs camaro
Engine: l31 swap
Axle/Gears: 2.7
running very rich
Im having problems with my 91 305 TBI the car is running very rich and at first i thought it was my timing being off but when i did my timing i was right on the mark. this all started after i had to replace my intake gasket. its was an easy job. but now it runs rich and feels like it might be missing. I set it six advanced and it gave me some power but then it made it really hard to start. I have put alot of new parts on it, the coolant temp sensor, the distributor cap rotor wires plugs. the injectors look like there using more fuel then when they did before i had to replace the intake gasket. this has me stumped. any help will be very appreciated.
Old Feb 10, 2013 | 05:16 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: running very rich
ok wow. is it running hot? did you bleed the cooling system when you refilled it. loosen the coolant temp sensor until it lets coolant seep out of it. this is to make sure there are no bubbles. did you make sure that you sealed the intake well and there are not leaks. did you restab the dizzy in the exact spot. did you leave a vacuum line off. is the egr sticking. did you put the wires back on the cap in the right place? very easy to do wrong.
Old Feb 10, 2013 | 05:27 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
There is your problem...."It all started after I had to replace my intake gasket". If it was good before and ran bad after, you messed it up. Time to start over. Check for vacuum leaks, look over every single thing you touched during the gasket replacement. I would start from scratch and set the timing to factory 0*. Worst case tare it all off and do it again the correct way. If it ran good before and now is bad after you worked on it.... well we know whats wrong.
Old Feb 10, 2013 | 06:31 PM
Car: 91 rs camaro
Engine: l31 swap
Axle/Gears: 2.7
I did set it back to o* i don't have vacuum leaks i checked for that. the distributor i put back in the exact same place. wires also. now im thinking EGR because when i took the intake off there was so much carbon on the EGR intake port that it was fully pluged. how do i check and see if the EGR is stuck open. and no the car is not running hot i kinda wish it was winter in michigan only place for spring and winter blizzard then rain all in the same day and i dont have much heat. coolant temp sensor burp did that first thing. another thing. when it gets warmed up the idle never comes down to 1k rpm its around 1.2k. could i have messed something up using some carb cleaner to clean up the TBI
Old Feb 10, 2013 | 08:42 PM
ex-x-fire's Avatar
Did you disconnect the timing connector when setting the timing?
Old Feb 11, 2013 | 07:39 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
any codes?
Old Feb 11, 2013 | 09:10 AM
Westech's Avatar
Car: 1991 Camaro RS
put back in the same spot? if you did not time it with disconnecting the wire and use a tining light... i bet thats your problem.... timing is off.
Old Feb 11, 2013 | 01:02 PM
Car: 91 rs camaro
Engine: l31 swap
Axle/Gears: 2.7
disconnect the ESC wire right the little brown and black one on the passenger side yup i did that. and no no codes are being thrown. i did have a code go off when i first bought the car coming from the distributor saying it was not picking up a signal. so i bought a new one. and I do have a timing light and i did use it.
Old Feb 11, 2013 | 02:00 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
got a picture of your plugs ?
Old Feb 18, 2013 | 05:12 PM
Car: 91 rs camaro
Engine: l31 swap
Axle/Gears: 2.7
I know this thread is old now but i found the problem and you guys might be surprised to know the awnser. before i did the intake gasket i did a tune up on the car and i put a set of NGK R spark plugs. the car was already running not as good as it could so i wanted to give it a tune up sorry guys. today i actually took my cheap *** out to the auto parts store and bought the AC delco plugs that went to the engine from the factory almost 60 bucks but i gave it a shot. this car has never ran this well there is no miss my car can even burn the rubber off at 40mph its almost enough to make me cry. the car runs perfect. thank you everyone for all the advice.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
