350 TBI surging idle, some stalling when put into gear.
Old Mar 4, 2013 | 01:57 AM
WhiteRabbit's Avatar
Alright guys. So after searching forum after forum on why my 92 RS 350 TBI will surge in RPM's during idle while warming up, then come near to stalling (sometimes actually stalling out)...I just want to know who can shed some light on this because it seems to be a somewhat common thing with these cars. The car was originally a 305 TBI but was swapped for a 350 (not sure if that helps...just figured I'd throw that out there). Thank you guys..
Old Mar 5, 2013 | 06:17 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 350 TBI surging idle, some stalling when put into gear.
It sounds like a lean condition. Is it still using the 305 throttle body?
Old Mar 5, 2013 | 09:06 AM
Yes it's the original throttle body from the 305.
Old Mar 7, 2013 | 06:31 AM
That could be your problem. I would use the throttle body and ecm from the 350 just to be safe.
Old Mar 7, 2013 | 12:32 PM
Where would be a good place to find those ?
Old Mar 7, 2013 | 01:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You need to get 55#hr tbi truck injectors not a complete throttle body and the correct ecm calibration.
Old Mar 7, 2013 | 01:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Thought you'd get better advice on the TBI forum.
Old Mar 7, 2013 | 03:49 PM
Ronny's Avatar
Are not the 305 and 350 TB's the same size. Injectors being larger for the 350 engine?
as stated surging is often lean.
Old Mar 7, 2013 | 03:57 PM
Engine: Lb9
Transmission: M20
right on the money Ronny the 454 is a larger tb bore though.
Old Mar 7, 2013 | 04:00 PM
Ronny's Avatar
And swapping in a 7.4L is not necessarily a good idea unless you need the flow.
Old Mar 7, 2013 | 06:48 PM
You can grab a complete tb and ecm from a salvage yard for $60...I meant a complete throttle body with injectors in my earlier post. I actually have a tb from a 350 sitting on a shelf in my garage. I don't need it.
Old Mar 7, 2013 | 06:53 PM
Engine: Lb9
Transmission: M20
you wouldnt , need a complete ecm just the L05 prom used in 89-92 b-body. I woulnt wast my on bone yard injectors but if your hard up
Old Mar 8, 2013 | 12:55 AM
Okay so the lo5 chip, injectors, anything else? I've been told to also look into a knock sensor and esc. True?
Old Mar 8, 2013 | 01:01 AM
This TB you have, how much would you want for it? I would also need an LO5 prom and what about ECM/esc?
Old Mar 8, 2013 | 10:30 AM
Engine: Lb9
Transmission: M20
The esc may work you would need to post the number on yours but the knock sensor would need to be changed to a standard motor products Ks7 or equilivent.
Old Mar 8, 2013 | 11:06 AM
I'll take $30 plus shipping. The complete tb is all I have.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
jklein337
Sep 19, 2018 06:23 PM
