What volts can i use safely to open/pulse the injectors?
Old Mar 19, 2013 | 01:32 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Isn't it like around 3 volts?
Old Mar 19, 2013 | 01:41 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: What volts can i use safely to open/pulse the injectors?
12 volts
Old Mar 19, 2013 | 01:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For TBI injectors use a light bulb such as an 1156 in series. This will limit the current so the injector doesn't fry. Note that without fuel flowing through the injector it will heat up quickly. So don't over do it unless there is fuel flowing to cool the injector.
RBob.
Old Mar 19, 2013 | 04:42 PM
FueledSoul's Avatar
I have them out of the pod descreened im planing on putting them in a ultra sonic cleaner... i heard 12the volts will fry them in no time...
Old Mar 19, 2013 | 04:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have used my otc 3398 works great, its not that much to have your injectors cleaned. You can also rig up a ecm power and ground and drp signal from a dizzy spun bye a drill. but dont apply a constant 12v unless you dont care about these injectors.
Old Mar 19, 2013 | 10:19 PM
FueledSoul's Avatar
I was able to open them with two D batteries in series, which got me 3volts... does anyone know if you can just buy the pin hole sized fillters on each injector? And where?
Old Mar 19, 2013 | 10:29 PM
Engine: Lb9
Transmission: M20
This is the only filter I know of on a tbi side feed injector.
http://injector-rehab.com/shop/GM-Isuzu-TBI-Filter.html
Old Mar 20, 2013 | 12:19 AM
FueledSoul's Avatar
it shows the side filter, and you can even see that hole in the pic with the injector
Old Mar 20, 2013 | 12:21 AM
Engine: Lb9
Transmission: M20
Huh, learned something new today
sahlomonic
Sep 20, 2015 07:15 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
Glowsock
Sep 6, 2015 06:40 AM
