Spark plug change gone horribly wrong. Need help
Old Apr 29, 2013 | 11:25 PM
scorpion92's Avatar
WHY HELLO. My names Zack, or you can call me idiot if you will for the rest of this thread. I just got my license back and picked up a 92 Camaro RS LO3, and changed plugs. went easy enough until the final plug. Plug 8. Shes a bitch. Got it out after some wedging of my arm underneath everything, but when i took the new one to slap in, well, theres this bolt right next to it that i had noticed, but didnt realize that it was hot until the socket completed a circuit to the spark plug, socket wrench, and my arm. Now that im back from the hospital, i want my car to run again. The car turns on, lights on, fan on, radio on, all that good shwit, but there is NO crank to it whatsoever. YES, i realize that i shouldve unplugged the battery (bout to shove a foot up some smart alic doctors rear), but somebody PLEASE point me in the right direction to be cruisin the streets again.
Thanks in advance,
Zack
Old Apr 29, 2013 | 11:38 PM
morgsie's Avatar
Re: Spark plug change gone horribly wrong. Need help
did you check the fuses?
Old Apr 30, 2013 | 12:19 AM
scorpion92's Avatar
Yeah, no luck. I was already out checking them all (hoping it was my VATS fuse) and theyre all registering fractions of an ohm.
Old Apr 30, 2013 | 12:31 AM
scorpion92's Avatar
Checked the NSS, not it either. Gonna cross the starter leads at the firewall now, will post back results
Old Apr 30, 2013 | 02:17 PM
jdawg1276's Avatar
Car: 1988 camaro
Maybe you burnt a ground strap if you have on I did in my old 86 iroc everything would work but it wouldn't crank but that was a Carb not shore if tbi has one
Old Apr 30, 2013 | 04:23 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
that bolt you hit was the starter it is on a fues link by the bat check that if it is good next check the starter relay if not that then it is the starter
Old May 2, 2013 | 04:09 PM
Keith91sub's Avatar
Car: Chevy Suburban-ish "Camaro" 1991
Engine: 383
Transmission: 4L80e
Yah, check the fusable link. That must have been one hell of a shock to send you to the hospital.
Old May 4, 2013 | 06:21 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
damn man, hope youre allright. fuse link as they suggested.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
tricky1
Aug 23, 2015 01:17 PM
