Periodic surging and poor idle
Old Aug 12, 2013 | 07:24 AM
Blade09's Avatar
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
Hi guys, so I've been trying to chase this problem for the last couple months it seems like. I was hoping to just have the new motor together and replace this bugger but its not going to be ready within the next couple weeks so I need to figure this out since I'm still driving the car.
I can't really describe the problem as anything more than a random, sporadic surging. It will happen in the middle of driving but I notice it most when I am decelerating at a red light. The car will surge down to ~200 rpm and then up to ~1500 over and over until I give it gas or it dies. And then its just fine?
This can happen 2-3 times a day or once in two weeks. Needless to say I had to coast into my spot a few minutes ago at work.
Any ideas?? I just replaced the TPS and no change.
Thanks guys.
Old Aug 12, 2013 | 05:21 PM
Schurkey's Avatar
Re: Periodic surging and poor idle
Put a REAL scan tool on that vehicle, tell us about commanded idle speed, how the IAC reacts, fuel trim (short- and long-term) and O2 voltage and crosscounts.
Old Aug 16, 2013 | 09:48 AM
Blade09's Avatar
Sorry boss, I wasn't ignoring you. I had to just park the car for a little while. I work 2 jobs so I just haven't had time to mess with it this week. I've got a buddy at the shop down the street that said I could hook it up but they only work til 5 so I'm going to try to get it there tonight.
It just seems to randomly miss at any amount of throttle. I will hold consistent throttle and then its as if I just let off really quick and get back on. It did it for most of a 20 minute highway drive earlier this week too.
What kills me is that some days its just fine...
Any tips to try until I can get it on a scanner?
Old Aug 16, 2013 | 09:59 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
check your injectors if you have a multimeter.
Old Aug 16, 2013 | 11:23 AM
Blade09's Avatar
I'll do that when I get home from work this afternoon.
Old Aug 16, 2013 | 03:08 PM
Cam455's Avatar
It can't hurt to check all the vacuum lines off the tbi. It's probably not them but here's the diagrams just in case. The one going to my maf sensor was broken and had similar symptoms, but constant not just every now and then.
Old Aug 16, 2013 | 03:10 PM
Cam455's Avatar
First one is manual trans second is auto
Old Aug 17, 2013 | 10:29 AM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Mine was doing the same thing. I was at wits end so I just re-did all my vac. lines and yes that was it.
Good Luck
Old Aug 18, 2013 | 08:45 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
this is a great image but there is one from the canister to a vacuum ball underneath it as well as if your car has cruise control check that vacuum line as well. Yes vacuum lines are the best cheapest place to look first as these lines are rotting out on our old cars goodluck and hope you find out what it is and let us know
Old Aug 19, 2013 | 06:33 AM
ex-x-fire's Avatar
Maybe the egr is getting vacuum at idle sometimes. Plug it off at the valve & drive it a couple days.
Old Aug 20, 2013 | 10:34 AM
Blade09's Avatar
Thanks for all of the great suggestions guys. I'm still trying to sort it out, I've been pulling 12 hour days and just haven't felt like messing with it much, but I'm finally back to a somewhat normal schedule.
Info to come!
Old Sep 18, 2013 | 07:29 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Anything new you one of left
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
Street Lethal
Sep 7, 2015 01:09 PM
