More Power
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
More Power
My motor is a 330hp GMP crate motor and I want more power. My question is
Can a TBI support it?
I have all the goodies. A GMP intake, MSD ign, Headers, Built 46mm TBI w/68# inj., Vacuum compensated adjustable FPR, A Corvette fuel pump, no smog, and I still only got 252rwhp on the dyno when it was tuned. But since then I have changed from a built 700r4 to a T5. If that makes a difference.
Can I swap the cam and intake and up my fuel pressure,and get what I want with out a complete redo?
My tuner says a TBI won't support 300/350 rwhp. He says go Carb. You guy on the form have got me here from being lost I know you'll get me the rest of the way.
I am running with a lot of 5gens and my goal is to smoke them. I already can out handle them now I have to be faster.
Greg
Greg
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: More Power
454 or Holley TBI, more CFM should up your output. I forget what the cutoff is, but the stock small block TBI is probably the choke point and your limiting factor at this point.
I think I read on another thread a while back that the smallblock TBI was only good for like 300HP (Crank HP if I recall correctly)
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: More Power
IIRC you have not yet swapped the cam, which is commonly reported to be the huge restriction of that engine.
For racing I would also go with a set of aluminum heads, weigh less and are less prone to detonation.
300rwhp is probably close to the limit of the GMPP intake.
A pair 80#hr injectors in the pod, a decent intake manifold, combined with a decent roller cam, a set of aluminium heads, around 10:1 CR, a decent tune and decent exhaust, should make 350rwhp easy.
Re: More Power
Thank you for your response. Now one more thing.
Send me a list of what to buy and where. It is killing me that the new Camaro is faster then me.
Re: More Power
Re: More Power
Sure I can, but I don't want to make any mistakes.
Should I keep vortec heads?
What brand of heads?
Why aluminimum can't I port my steel ones?
I want to learn from others.
I realize I'll need;
heads or at least work
cam preferably complete roller
intake
new injectors
a tune.
I have good exhaust.
now I go to Summitt and fill my cart.
intake
new injectors
a tune.
Car: 1987 camaro Z28
Transmission: manual
Re: More Power
you ever race your car at the track...if yes ...what is you 1/4 mile time...v6 gen 5 Camaros run about 14.40 as far as v8 5 gen you will start braking your drivetrain befour u outrun them...vortec heads are great heads don't undarestamate them ...here is a good roller cam http://www.jegs.com/i/GM+Performance...FU8LMgodTWMAMA
change the springs too ...stock springs are weak wont let u go pass 5500 rpm...try double pumper or 4 barrel tbi
Car: 91 Trans am
Re: More Power
You a re looking for some serious horsepower, probably time for some aftermarket aluminium heads.
first you should figure out the required combustion chamber to get around 10:1 CR with your block https://www.uempistons.com/index.php...tors&type=comp
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Personally I would work on the suspension, chassis and driveline to get the car capable of hooking and surviving the increased power first.
I have had pretty good luck with the LT4 Hotcam in a a few setups.
http://www.hotrod.com/cars/project-v...ckage-install/
Re: More Power
My suspension/chassie and drive line is done. I have spared no expence on this car. I have an a chance to buy either a 2014 engine and trans out of an SS or a ZL1. I just don't have 10 grand laying arround.
Should I keep Vortec heads?
I found some Bridox heads and intake.
I can go rite to Summit and get it all.
I will talk with my tuner and see what he has to say.
Re: More Power
So I should buy new heads just so that they are alumium?
Should I stay with Vortec heads? That limits the choises.
What about cam? Roller for sure but what specs?
Which intake? I am thinking a RPM intake air gap maybe.
Some one point me in the rite diorection.
Re: More Power
How much power you want to make?
What is your desired RPM range and use?
The correct direction is here.
Re: More Power
Well as usuall the budgit is high. I don't want to spend any more then 5 grand or I might as well put an LS in.
I am making 252 to the wheels now out of a 330hp rated crate motor. But that was going through a 700r4 to my Moiser 12 bolt with 373 gears with 275/40/18's. Now I have a T5 trans and I haven't retuned it. I want to make a real 350/400 to the wheels. I think my drive train will put up with that.
I have a stick so I want to beleave the RPM range should start at 1500 and go to 5500.
Any help would be great. I just don't want to just buy parts all ***** nilly not knowing if their to much or not enough.
Thanks Greg
Thanks Greg
Car: 91 Trans am
Re: More Power
The great thing about vortec heads are good flow #'s due to the increased height of the intake ports, but any respectable aftermarket cylinder head will flow good to better than vortecs.
A cam in the .490-.500 lift, 112 LSA, 210-215 duration range should be nice with aftermarket heads. Something like the CCA 8-501-8. Could play with comp cams camquest, to get an idea.
I would go with a single plain intake but not air gap, if keeping TBI.
Re: More Power
Should I keep the Vortec heads?
It would be cheeper just to go to regular heads.
Since I have to get an intake too.
Car: 91 Trans am
Re: More Power
Going by the 9:1 CR with 64 cc cylinder head volume description of the 330hp crate engine, brings us to an approx 16 cc dish piston.
Meaning it will require a 54 cc cylinder head volume to get up to 10:1 CR. Standard cylinder head volume of 350ci heads is in the 62-64cc range.
If you feel confident to work on the engine, you could swap the pistons, 7cc for 64cc heads or 8cc for 62cc heads. Though the whole rotating assembly will need to be rebalanced with the new pistons.
Maybe at that point it would also be a good idea to deck the block so that you can use a thicker 0.039 head gasket like this http://www.summitracing.com/int/part...make/chevrolet otherwise the only choice you have is this 0.015 in. cylinder head gasket http://www.summitracing.com/int/part...1094/overview/
I would not keep vortec heads if I could go with a set of budget aftermarket aluminium heads http://www.hotrod.com/how-to/engine/...#__federated=1
Re: More Power
So throw the Vortec heads out. I'll just buy a new top end and cam
Will I be able to keep the TBI?
How about the holley 4bbl TBI?
Will it work with my stock computer? or does it have it's own?
Or should I just throw in the towle and put a carb on it?
I want about 350 to 400rwhp. And I want decent mpg.
When it was running good last summer I got over 20mpg hwy.
I run with a bunch of guys with 5th gens and I am pissed that they walk away from me. Anyone can buy a new car and it's fast and so could have I. But I'm a 3rd gen guy and I like making my own.
Car: 91 Trans am
Re: More Power
Some way or another you will have to resolve the low CR pistons, though looks like Dart makes a 49 cc combustion chamber cylinder head http://www.summitracing.com/int/part...111f/overview/ this should bring CR to around 10.6:1, which would be perfect. EDIT I just noticed it is an iron cylinder head, bad luck! Something similar made of aluminium would be perfect.
With a reasonable cam like the one mentioned above it should brake in the 350+ rwhp easy, though it will probably peak at around 5700rpm.
Someday I will try this out http://www.summitracing.com/int/part...make/chevrolet
A pair of big TBI injectors, VRFPR, tuned EBL is all you need to fuel it.
Though first thing to do is figure out what pistons are in the 330hp crate engine, CR is important.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
The 300 and 330 hp 350s have 12cc dished pistons with metric ring pack ala L05 or L31.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: More Power
My tuner says a TBI won't support 300/350 rwhp. He says go Carb. You guy on the form have got me here from being lost I know you'll get me the rest of the way...
Car: 91 Trans am
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Everything I have seen is advertised at 9.4:1. Its the exact same long block save cam/lifters they use as the Marine 350 and a L31 Vortec 350. The pistons are typically .015" down the hole and GM runs a .028" compressed head gasket.
Re: More Power
I have the number for the motor.
the pistons are cast aluminum and 9.1:1
The number for the engine is: 12486041
Car: 91 Camaro
Engine: 355 Carb
Transmission: 5 speed
Axle/Gears: 342 Posi
Re: More Power
Oh,you want horsepower. I don't know why you went with a crate motor. You should have went with a forged small block with a c/r of around 8:1. Aluminum heads, set up with a procharger F 1 blowing through a "Fast" 30401 fuel injection system. Just my thoughts on good horsepower.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Its the same block, crank, rods, pistons, heads and head gaskets as a L31 and it is 9.4:1 advertised in a truck or a boat. I have had one torn down to the bare block. Only difference between the 330 hp 350 and a L31 is the provision for a mechanical fuel pump on the crate engine and a hydraulic flat tappet 212/222 iirc cam rather than the 191/196 roller of a truck or a 196/206 roller boat.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
http://m.summitracing.com/parts/nal-12530283
How the same list of parts magically become 9:1 in a GM crate engine is a mystery to me. I have crunched the numbers of an engine I had torn apart and it came out at something like 9.39:1.
Re: More Power
Dude I am just reading from the engine build sheet. I punched in those numbers into the internet and it came up with the build sheets.
http://www.gmpartsdirect.com/perform...ATID=1099.html
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
The Hotcam in your current setup will make a big difference in HP. You could also go with the GM 846 aka Crane 109831 cam. 222/230 @ .050 roller with .509/.528" lift on a 112* LSA. Makes power from ~2,000 to 6,200 rpm. If that is too much for your tuner, you could also go with the GM 845 aka Crane 109821. It is 214/222 @ .050, .488/.509" on a 112* LSA.
Re: More Power
So a thinner head gasket and a better cam? What about the injecters and fuel pressure?
Or are you saying just a hotter cam? Leave the heads alone?
That sounds more like it. I'm not talking 500rwhp just a mild 300 to 350.
Car: 91 Trans am
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Now that we have that all hammered out I'll be ok with just a cam. No new intake? What about injectors?
I rode in my friends 5th gen and it is fast. I want mine at least close. At 250hp they leave me in their dust. I want 350rwhp. Can I do it with just bolt on parts? IE... a cam, heads and intake. I know I can do more but my engine is new and I hate to replace it.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Re: More Power
Thanks for the info. So why do I need to open the push rod holes? So I'll need new pushrods to rite? What about new head gaskets? Anything special? Should I have the heads ported or anything? How about the injectors and fuel pressure?
Re: More Power
Wow thanks. I have read this over and over and it is finally making sense.
1. Head work to make it take 1;6 to 1 roller rockers
2. LT4 hot cam any specific grind with the springs that go with
3. roller lifters if I can
4. How about the thin head gasket?
I already have a Hp fuel pump and a 46mm TBI. I am running 68# injectors. How am I going to fuel this.
How do you put N2o on a TBI engine? Is there a plate for under the TBI or do I direct inject it?
Thank You now I just need to figure out what is wrong with it and get it running right again.
Re: More Power
I picked out this stuff.
http://www.summitracing.com/parts/nal-12480002
http://www.summitracing.com/parts/nal-12371042
I that what your talking about? So do I need to have the heads machined to work?
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Finally don't forget you will need the camshaft retainer plate and bolts that sits behind the camshaft timing sprocket as well as a new timing chain. I have had good luck with and recomeend the Cloyes 9-1157.
http://www.summitracing.com/parts/na...8501/overview/
http://www.summitracing.com/parts/CLO-9-1157/
Finally when you go back together with the engine, I like using these head gaskets to give you better quench and more compression.
http://www.autozone.com/gaskets/head...nce/75445_0_0/
The LT4 Hotcam usually drops in 3* advance on a 109* ICL but was designed for use in a 10.8:1 compression engine. With the steel shim style head gasket, stock head, stock piston, stock deck height, etc you come out about 9.5:1 and ~ .041" quench with a pump gas friendly 7.7:1 dynamic compression ratio. I would advance the cam 4* over the drop-in (7* total) and bring it down to a 105* ICL. It will bring the powerband down slightly to better match with the TBI and dual plane while bringing vacuum up a little from the earlier intake closing.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
You are going to need about 28-30 psi of fuel pressure to fuel this setup and I would recomeend going to route of a VAFPR if you have the EBL. With 14 in/hg of vacuum on the VAFPR your idle fuel pressure will drop about 7-8 psi down from 30 to about 22 with the 68#. I would check into one of the TBI injector guys to flow the injectors. Flow them at 11 psi, at 22 psi and say 33 psi so that you can plot the injector flow along the curve linearly. IIRC you are running the EBL and will need that information to set the Base Pulse Constant table in the ECM code to allow for proper fuel calculations with varying pressure.
If you put N20 on this engine you could use either the NOS kit designed for a TBI engine or convert to a carb intake and use a carb style plate. You will need a little help from the nitrous kit manufacturer due to the fuel pressure you will be running to get the correct fuel pill sizes.
Re: More Power
Good gosh all I can say is thank you.
I am going to buy the gasket kit too.
I am going to get my basket together and I will post it so you can tell me if I have it all. Oh and don't I already have a Cam Retainer Plate? Do I need to buy another?
Re: More Power
I just need to get the rest of the gaskets. I need a cam change kit.
http://www.summitracing.com/cart
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Your engine if its the 330 HP 350 crate will have a flat tappet cam and those do not use a retainer plate. The crank sprocket also has a larger bolt pattern on the flat tappet cam than the roller. If you are getting a new timing gear, you might as well get a single roller chain. They run with less friction, less wear and greater accuracy and strength.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
So just thought I would post up some of the information I have gathered on the GM 300/330 HP 350 cam and the LT4 Hotcam as the advertised duration numbers for both from GM are bogus compared to the aftermarket. On a degree wheel, I have personally degreed both cams.
The 300 HP 350 crate engine cam
262/272 @ .006
212/222 @ .050
.290/.306" lobe lift (.435/.460" w 1.5 rocker)
109* ICL, 116* ECL
Which calculates 112.5 LSA
The LT4 Hotcam
272/281 @ .006
218/228 @ .050
.328/.328" lobe lift (.525/.525" w 1.6 rocker, .492/.492" w 1.5 rocker)
109* ICL, 115* ECL
Which calculates to 112* LSA
I modeled the engine before and after cam/rocker/head gasket swap using a 650cfm 46mm TBI unit and small tube shorty style header with a decent exhaust. I am showing gains of 73 HP @ 5,500 rpm and 80 HP @ 6,000 rpm with no loss of torque anywhere. With the smallish TBI, dual plane intake, somewhat restrictive exhaust setup, and 4* advanced Hotcam I am modeling a peak to peak HP gain of 59 hp @ 5,000 rpm and a gain of 39 ft/lbs peak to peak. I think that would put a HUGE smile on your face. I also modeled the engine using the crappy flowing hecho en mexico garbage vortecs being made now from what I can only assume are totally worn out casting cores.
262/272 @ .006
212/222 @ .050
109* ICL, 116* ECL
The LT4 Hotcam
272/281 @ .006
218/228 @ .050
109* ICL, 115* ECL
Re: More Power
http://www.summitracing.com/cart http://www.summitracing.com/parts/fel-1094 http://www.summitracing.com/parts/nal-10168501 http://www.summitracing.com/parts/nal-12371042 http://www.summitracing.com/parts/nal-12480002
I am having a hard time finding a gasket kit. But this is it and I am really liking the numbers.
The motor has a name plate on the oil filter housing that says it was made in 1999. I hope it has the good heads but even with the Mexican castings those are impressive.
Could I do better with a different intake and an adaptor plate?
Thanks I am going to get the parts coming.
Re: More Power
What about just buying alum. heads? I was looking at this combo.
http://www.summitracing.com/parts/sum-cedl404/overview/
Still getting the cam but this is a good price for the heads and intake. or I could but the heads all by them selfs. save on machine work.
I just want to do it rite this time and not half *** it.
Happy Easter
Happy Easter
Re: More Power
Hey man here is my new basket what do you think?
Price Qty Total
Airflow Research (AFR) 0912 - AFR 190cc Vortec Eliminator Street Cylinder Heads
Click here for more information about Airflow Research (AFR) 0912 - AFR 190cc Vortec Eliminator Street Cylinder Heads
AFR SBC 190cc Street Vortec Style Heads, straight plug, 65cc chambers, complete w/parts ; Qty: 1 pair
AFR-0912
$1,668.40
Update
$1,668.40
Remove
Free Shipping
ARP 134-3701 - ARP High Performance Series Cylinder Head Bolt Kits
Click here for more information about ARP 134-3701 - ARP High Performance Series Cylinder Head Bolt Kits
Cylinder Head Bolts, High Performance, 12-Point Head, Chevy, Small Block, Kit
ARP-134-3701
$88.97
Update
$88.97
Remove
Cloyes Gear 9-1157 - Cloyes Street True Roller Timing Sets
Click here for more information about Cloyes Gear 9-1157 - Cloyes Street True Roller Timing Sets
Timing Chain and Gear Set, Street True Roller, Single Roller, Iron/Steel Sprockets, Chevy, 350, L31, Set
CLO-9-1157
$56.97
Update
$56.97
Remove
Fel-Pro 1094 - Fel-Pro Performance Head Gaskets
Click here for more information about Fel-Pro 1094 - Fel-Pro Performance Head Gaskets
Head Gasket, Stainless Steel Shim, 4.100 in. Bore, .015 in. Compressed Thickness, Chevy, Small Block, Each
FEL-1094
$22.97
Update
$22.97
Remove
Mr. Gasket 136G - Mr. Gasket Intake Gasket Sets
Click here for more information about Mr. Gasket 136G - Mr. Gasket Intake Gasket Sets
Gasket, Manifold, Intake, Rectangle, 2.30 in. Height,1.31 in.Width, .125 in.Thick, Chevy, Small Block, Vortec
MRG-136G
$27.29
Update
$27.29
Remove
Chevrolet Performance 10168501 - Chevrolet Performance Camshaft Locking Plates
Click here for more information about Chevrolet Performance 10168501 - Chevrolet Performance Camshaft Locking Plates
Camshaft Retainer Plate, Steel, Chevy, 350, 2nd Design, 3.294 Bolt Center, ZZ3-ZZ4, Each
NAL-10168501
$12.97
Update
$12.97
Remove
Chevrolet Performance 12371042 - Chevrolet Performance Hydraulic Roller Lifters
Click here for more information about Chevrolet Performance 12371042 - Chevrolet Performance Hydraulic Roller Lifters
Lifters, Hydraulic Roller, Chevy, Set of 16
NAL-12371042
$232.97
Update
$232.97
Remove
Free Shipping
Chevrolet Performance 12480002 - Chevrolet Performance LT4 Hot Cam Hydraulic Roller Cam Kits
Click here for more information about Chevrolet Performance 12480002 - Chevrolet Performance LT4 Hot Cam Hydraulic Roller Cam Kits
Cam and Valvetrain, Hydraulic Roller Tappet, Duration at .050 in. 218/228, Lift .525/.525, Chevy, 5.7L
NAL-12480002
$595.97
Update
$595.97
Remove
Free Shipping
Chevrolet Performance 12496822 - Chevrolet Performance Eliminator Vortec Intake Manifolds
Click here for more information about Chevrolet Performance 12496822 - Chevrolet Performance Eliminator Vortec Intake Manifolds
Intake Manifold, Eliminator Vortec, Single Plane, Aluminum, Natural, Square Bore, Chevy, Small Block, Each
NAL-12496822
$333.97
Update
$333.97
Remove
Free Shipping
Chevrolet Performance 12550027 - Chevrolet Performance Vortec Intake Manifold Bolts
Click here for more information about Chevrolet Performance 12550027 - Chevrolet Performance Vortec Intake Manifold Bolts
Bolts, Intake Manifold, Steel, Natural, Hex Head, Chevy, 5.0, 5.7L, Each
NAL-12550027
$3.97
Update
$31.76
Remove
Nitrous Express (NX) 20218-10 - Nitrous Express GM TBI Nitrous Systems
Click here for more information about Nitrous Express (NX) 20218-10 - Nitrous Express GM TBI Nitrous Systems
Nitrous System, 10 lb Bottle, GM TBI All, 50-75-100-125 HP, Kit
NEX-20218-10
$895.41
Update
$895.41
Remove
Drop Ship
Special Order
Free Shipping
Trans-Dapt Performance Products 2210 - Trans-Dapt Performance Throttle Body to Carbureted Manifold Adapters
Click here for more information about Trans-Dapt Performance Products 2210 - Trans-Dapt Performance Throttle Body to Carbureted Manifold Adapters
TBI Adapter, 3-Bolt TBI to Square Bore Carbureted Manifold, Steel, .250 in. Thick, Gaskets, Hardware, Kit
TRD-2210
$39.97
Update
$39.97
Remove
Price Qty Total
AFR-0912
$1,668.40
Update
$1,668.40
Remove
Free Shipping
ARP-134-3701
$88.97
Update
$88.97
Remove
CLO-9-1157
$56.97
Update
$56.97
Remove
FEL-1094
$22.97
Update
$22.97
Remove
MRG-136G
$27.29
Update
$27.29
Remove
NAL-10168501
$12.97
Update
$12.97
Remove
NAL-12371042
$232.97
Update
$232.97
Remove
Free Shipping
NAL-12480002
$595.97
Update
$595.97
Remove
Free Shipping
NAL-12496822
$333.97
Update
$333.97
Remove
Free Shipping
NAL-12550027
$3.97
Update
$31.76
Remove
NEX-20218-10
$895.41
Update
$895.41
Remove
Drop Ship
Special Order
Free Shipping
TRD-2210
$39.97
Update
$39.97
Remove
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
So I may be overthinking here, but why pay a preminum for the Vortec stuff if you are changing both the heads and the intake manifold??
I would go with a set of heads drilled with the pre 86 intake pattern and use either of these manifolds if you are staying TBI.
http://www.summitracing.com/parts/ed...make/chevrolet
http://www.summitracing.com/parts/edl-2901/overview/
The dual plane will be a little more streetable and forgiving with the tune than the single plane, especially in cooler weather. The performer RPM is a great manifold.
While I think AFR heads are great, you are really surpassing what a TBI engine with a Hotcam needs to run really well and moving up into 4bbl carb or 4bbl aftermarket TBI kind of power.
That being said I have the ETec170s on my Express van after one of the Hecho en Mexico heads cracked when I lightly overheated the engine after the radiator drain plug broke going down the highway. I drove it for 6 months before discovering the head issue. Pulled the engine, swapped over to the ETecs with a 215/220 @ .050 custom grind comp cam and it runs strong from off-idle through 6,200 rpm.
Re: More Power
I think I have it.
I'll just stay with what you talked about earler.
Have the heads done to handle the 1:6 rockers &
the Hot Cam and save the money for the next build.
But I think I'll do the NoS just for fun.
