camaro rs 1992 fuel injection problems
I Have a 1992 camaro tbi injecto rs but it turn on but went I accelerate the injection goes down it does inject but less on low rpm it dont accelerate it just try to turn off like is miss fire or something because it don get enough Gas IT DOES INJECT SPRAY BUT ON LOW RPM ON HIGH TOO BUT LESS GAS it dont run good cuz it dont accelerate what you think is wrong...
Car: 1983 G20 Chevy
Transmission: 4L60
Re: camaro rs 1992 fuel injection problems
Car: 1983 G20 Chevy
Transmission: 4L60
The fuel pressure
Should be 9-13 psi, but I have found these TBIs run best at 12-13 psi even stock.
http://www.autozone.com/test-scan-an...er/232719_0_0/
Should be 9-13 psi, but I have found these TBIs run best at 12-13 psi even stock.http://www.autozone.com/test-scan-an...er/232719_0_0/
Car: 1983 G20 Chevy
Transmission: 4L60
The last TBI regulator spring I removed from a car running about like yours with only 5-6 psi of fuel pressure on the gauge looked about like this. The one I had was only in 3 pieces, but same effect. Weak fuel pressure. It would idle perfectly but had long cranking times and fell on its face at any throttle position.
I just try to hear the fuel pump today and it sound like everithing work even went it happens but idk
I even press the fuel line but went I accelerate I feel like the gas goes down SORRY TO MAKE MANY QUESTIONS im new into this fuel things lol
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
