All TBI nitrous users
Old Dec 19, 2001 | 03:52 PM
TMoNeE's Avatar
Car: 87 Z28
ive got an 89 rs with the 305 l03, what nitrous kits do you guys use... include part #, company, price, and where u bought it if possible.. thanks guys
Old Dec 19, 2001 | 08:21 PM
TBI305Camaro's Avatar
NOS-05153 is made for TBI 5.0 liter cars...and trucks itll work fine and its around 550$ for an 100-150 shot ...youll kill the motor eventually running n2o the lo3 cant take it
Old Dec 20, 2001 | 10:15 AM
94'_SS's Avatar
Why can't the lo3 take nitrous? As I understand it the lo3 has basicily the same type internals as the production 350. I dont think GM made the lo3 any weaker just because it was a low output motor which was due to crappy selection of heads and cam. If you have a good fuel pump and regulator, good ignition system, and common sense (dont use above the recomended 125 shot) nitrous should not be feared as something that will blow your motor into little pieces. I have friends who have used nitrous for years on their daily drivers with out problems. Nitrous gets a bad rap when guys using 150 shot hits on stock cars with worn fuel and ignition systems that could not keep up with that much nitrous scatter a motor.
Old Dec 20, 2001 | 12:59 PM
un4givin89's Avatar
Its reccomended no more than 75hp shot for a 305, and you won't ruin the motor if you've already done a head and cam change and intake.
Old Dec 20, 2001 | 11:52 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I just read in a mag (can't remember which one) that NOS now makes a nozzle kit that is designed for wet flow intakes. It mounts on the air cleaner stud in the air cleaner, and sprays Nitrous and Fuel from the top like a TBI does.
My wife works at Barnes & Noble and brings me home free magazines. I'll have to hunt through them to find it, then I'll let you know about it.
I don't sound like a bad deal. It's designed for cars like ours that have very little hood clearance. Although IIRC, it's designed for 4 barrels.
I'll let ya'll know,
AJ
Old Dec 21, 2001 | 12:07 AM
AJ_92RS's Avatar
Here's the link to the NOS web site.
http://www.nosnitrous.com/HiOctn/Pro...densystem.html
And here's a pic.
It does say that it's for 4 barrel carbs, but I bet it could be modified. After all, that's what we all do so well!!!!!!
AJ
Old Dec 21, 2001 | 09:26 AM
where could i get a NOS kit that would only give me a 75hp shot? that sounds reasonable and probably wouldnt be to hard on the engine...id say 100 would be rough on a 305 TBI exspecially with 100k miles on it like mine...i would like to have a 75 shot...would give me more than enough boost to take a 5.0 mustang hell maybe even a 4.6 GT
Old Dec 21, 2001 | 10:10 AM
AJ_92RS's Avatar
Did you go to the site above?
If so you'll see all the part #'s. If you click on the 'Online Catalog' section up top, then 'GM EFI' section on the left, they have a 75-150 set up for TBI.
Just copy that part # and go to www.summitracing.com, go into the 'Online Catalog' option at the top, then click on the 'Manufactures Part# Search' on the left task bar. Look for "NOS" in the list, then enter that part #. It'll give you a price, etc.
AJ
Old Dec 21, 2001 | 02:16 PM
TMoNeE's Avatar
Car: 87 Z28
Does anyone have that kit that has modified it? Someone told me about a kit like this that could be used with TBI, hmmm let me know.
Old Dec 21, 2001 | 11:34 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
TBI305CAMARO....I wouldnt go picking on any 4.6 GT's unless you have more done to your car than a 75 HP shot, but who knows, if you know how and when to use it anything is possible. I forget who said it but I remember reading on this board that a stock 305 can take a 100 shot and a stock 350 can take a 150 shot without any worries if your fuel and ignition systems are running right. I would think if you know what your doing you could run nitrous all the time and not have to worry about breaking anything.
Old Dec 22, 2001 | 12:49 PM
Jza's Avatar
Jza
I'm not saying that's right or wrong, because every motor is different, but I am saying take everything you read on this board with a grain of salt.
Old Dec 26, 2001 | 05:29 PM
TMoNeE's Avatar
Car: 87 Z28
cmon i know there is more nitrous users... let me know people..
Old Dec 26, 2001 | 06:42 PM
deadtrend1's Avatar
camaroracer1992 uses NOS ... he used to run it in a 305 but he just switched to a 350 i think. http://members.aol.com/j007golden/joerace.html
it gives a few part numbers that he used i think there, and his email addy
Old Dec 29, 2001 | 12:20 AM
he told me he ran 125shots into a completely stock 305 with 70k miles on it
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
