Car idles at 1750RPM when cold.
Car: C1500
Originally posted by brodyscamaro
open loop
open loop
I just wanted to claify something here. Open loop happens when you first start your engine and lasts until it reaches operating temperature and the O2 sensor is hot enough. When in open loop the ECM doesn't moniter the O2 sensor and calculates how much fuel to put i the engine from tables in it's memory. An engine also goes into open loop if an error code is tripped. This is also known as limp home mode. It is used to that the engine continues to run even if a sensor gets messed and returns a messed up reading that would normall cause the engine not to run. Closed loop is how the engine normall runs when it is warmed up. In closed loop the ECM monitors the O2 sensor and tries it's best to keep emissions low as opposed to open loop where the ECM just wants to warm the engine up or keep it running. At WOT the engine also ignores the O2 sensor and richens up the mixture greatly for more power
