TBI Spacers
Old Dec 22, 2001 | 06:06 PM
DrekkenX's Avatar
TBI Spacers
Hi.. I have an 89 RS with a 305 TBI. I have had great difficulties finding some place with a TBI Spacer . I was wondering if anyone had some suggestions... Thanks in advance..
Tom
Old Dec 22, 2001 | 07:03 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
www.turbocity.com
Old Dec 22, 2001 | 08:40 PM
DrekkenX's Avatar
T H A N K Y O U !!!!!!!!
Old Dec 22, 2001 | 09:48 PM
TMoNeE's Avatar
Car: 87 Z28
Are spacers worth it.. i go back in forth on what i read.. some say yea. some no... what you guys think?
Old Dec 22, 2001 | 10:10 PM
iroc22's Avatar
Sure spacers are worth it they add more plenum volume for your cylinders to draw air/fuel from.
Old Dec 22, 2001 | 11:58 PM
Jza's Avatar
Jza
"Worth it" is going to depend on what you pay for it.. I wouldn't call $70 for the marginal gain you get "worth it". Make your own, that's "worth it". That's why you get different responses.. people have different ideas of "worth".
Old Dec 23, 2001 | 02:50 AM
JPrevost's Avatar
Car: 91 Red Sled
This is true but too far and the fuel falls out of suspension = crappy idle quality and off idle is so so.
I consider the spacer a tuning aid. WOT and a cam to match, yeah, the spacer could help a little. Worth it, I dont' think so. For the price of 2 spacers you could have a homemade spacer and a new intake and make your own adaptor plate = WORTH IT.
Don't forget the price of the gasket kit which isn't cheap.
Old Dec 23, 2001 | 07:17 AM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
I had a great experience with a spacer. I think the reason was because of the engine changes I had done. My car used to run really crappy until it was fully warmed up. The spacer changed that dramatically. I attribute the difference to the engine mods increasing the speed of the fuel mixture causing the fuel to hit the floor of the manifold. I made a 1/2" spacer and was amazed at the difference so I made a 1" spacer and cant say I saw any additional change.
I was skeptical about how much good it would do because I'm the type to figure "if it's that good, the factory would do it" but since I have access to machine shop and aluminum plate, I decided to give it a try.
Is one worth the money? Everybody's value of money is different. I got the gaskets from GM dealer for $2 each. Yes, $2.
I don't know how you can compare the cost to an new manifold and adapter when manifolds alone are over $100. And my idle and off idle is terrific.
I'm not trying to rip anyone but the value of any change needs to be looked at in regards to what is already there. For a completely stock engine, maybe not. But then, I don't believe a manifold alone would provide much difference either.
Old Dec 23, 2001 | 05:13 PM
iroc22's Avatar
Yeah I agree having a new intake will do wonders since the stock unit cannot breathe in the upper RPM's
S10K20
Oct 7, 2015 06:45 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Glowsock
Sep 11, 2015 11:09 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
