Happy Third Gen Noob Entering the room!!!!
Old Mar 7, 2016 | 07:09 PM
TeddyOfTorment's Avatar
Car: 1992 Cheverolet Camaro Rs.
Engine: 305 tbi
Transmission: t5 5 speed
Hello fellow third gen follower. As the title says im a noob. I have always wanted a thrid gen camaro ever since they came out. And a week ago, i became the owner of not one, but TWO! couldnt be happier. But alas, they need work. one is a roller, the other i have determined a VATS problem, among other electrical probs. (since i found someone went crazy with wire cutters and electrical tape) So, when i got it, the fuel pump, starter, and electric fan has been hard wired to a toggle switch an push button. As a mechanic, I started at the top. It wouldnt start. Found fuse for fuel pump blown, fuel relay missing, fan relay missing. After I made sure it was getting fuel to throttle body, still no start. Poured fuel directly into tbi it started then quit. Thats where things get interesting. With my lucky power probe i found the injectors arent getting ground. So to the internet i went. Post here and else where told me to look at the vats system. I found the connection between the wire from the key to connection under dash severed. The original key cylinder has been changed, but as luck has it, i found a chip key in the passenger seat. I measured the resistance, and ordered the correct bypass for it. Thats where i am now. Gonna install tomorow. i just wanted to share my progress. I hope it will start tomorrow. But if not, where should i do then?
Old Mar 7, 2016 | 07:46 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Happy Third Gen Noob Entering the room!!!!
Welcome to TGO! The fellas on here need more information on the car. What year, motor, etc. The more information the better. You can also do a search to find a ton of information on here.
Old Mar 7, 2016 | 08:04 PM
Engine: 305 tbi
Thank you very much. Glad to be here. The one im working on is a 1992 rs 305 5 speed. t-tops. the roller is a 1989 rs.
Old Mar 7, 2016 | 08:33 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Fill in your profile. Someone may be close by who can provide some hands on help if needed.
anesthes
Feb 21, 2016 08:20 AM
krounds
Feb 12, 2016 07:22 AM
tcrisp
Feb 10, 2016 04:57 PM
Billgluckman
Feb 9, 2016 07:24 PM
sgp0511
Feb 8, 2016 04:16 PM
