Car wont start with out ether runs rough
1991 305 TPI Z28 coupe. Started running rough after warmed up, then died while going down hyway after warmed up. will start again with ether after cooled down. Replaced : throttle position sensor , temp sensor, ignition control modual , fuel filter, ECU, maf sensor. Im going to sell it for parts ifg Ican't get it running.All these things I replaced are from tips on here. does any one know what causes this or is it oen of those things that might be 1 to 1000 different things?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Car wont start with out ether runs rough
You've already sunk some dough and time into this. A little more might do the trick.
The ignition coil is cheap and easy to change. May want to give that a go. They can respond to heat soak when they start to fail.
It can't be that many things.
So just to be clear:
Cold it starts fine and runs fine. Then when it warms up it dies until cooled down again?
Before it did this was it running fine?
Axle/Gears: 10 Bolt 2.73 Open
If your engine has TPI (Tunes Port Injection), you'll want to post this in a different section, or ask a Mod to move it for you. This section is for TBI (Throttle Body Injection) posts.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have you omed the injectors ? Stock multecs fail when warm the coils short out.
Put a scan tool, a compression tester, and a fuel pressure gauge on that thing, and find out what's actually wrong. Fix only the true problem.
Engine: 350 TPI L98
Transmission: WC T5
^^ agreed but he didn't mention the coil. $35, 20 minutes, and a likely suspect in heat soak issues. Even though I would be smarting from those parts too, the coil is mighty tempting...
Point being, diagnosis before parts replacement.
Engine: Lb9
Transmission: M20
Might be to late looks like the owner has given up
https://www.thirdgen.org/forums/cama...ale-cheap.html
Engine: LS1, LB9, L03
I'd check fuel pressure at the fuel filter under the car first, then ohm out the injectors if pressure is good. If pressure is not good at the fuel filter, then I'd suspect the fuel pump.
dr.watkins9
Sep 22, 2016 03:33 PM
