Correct TPS Horizontal or Vertical Connector?
Old Oct 31, 2018 | 06:59 PM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
This is the Throttle body on my car, 17088028, which is correct for '88. I also have another throttle body, 17089062, which is correct for '89-'90, removed from a car in a junk yard early 2000s. Both have the horizontal connector version of the TPS.
The ACDelco 213-905, which is indicated as the replacement for my '88, has a vertical connector, according to the product picture. Many of the other generic replacements are vertical as well, but some are horizontal. I'm being told that vertical is correct but I'm skeptical that it will fit under the air cleaner. So, what is correct?
The ACDelco 213-905:
Old Oct 31, 2018 | 07:26 PM
mecham84's Avatar
Car: '84 Trans am ‘86 Iroc
Engine: 305 auto, 305 auto,
Transmission: Automatic
Re: Correct TPS Horizontal or Vertical Connector?
You need to get the same style connector (horizontal) cause the arm also will be in the opposite direction. I had the same problem. I found one on ebay that matched what I had.
Old Nov 1, 2018 | 01:47 PM
Schurkey's Avatar
Is this what you mean by "horizontal" versus "vertical"? I'd have said "flat-" versus "round"-body connector.
Use the TPS that fits your wire harness.
My '88 uses the flat (horizontal) connector, not the round (vertical) connector--although there's wire harness adapters to convert one to the other.
Old Nov 1, 2018 | 01:50 PM
Engine: 305 (LO3)
No, one is not round. You can see what I mean in the pictures I included. Same connector style, different orientation.
Old Nov 1, 2018 | 04:35 PM
mecham84's Avatar
Not sure if you found it yet but on my box it shows brand and model....
Standard TH39 Throttle Position Sensor
Old Nov 1, 2018 | 08:17 PM
Engine: 305 (LO3)
I haven't, yet. Thanks. Any idea if new ACDelco is available? Digging through eBay, I found NOS GM 17111725 and 17111787. No idea if either is correct. The apparent difference is that one is adjustable and the other is not.
Old Nov 2, 2018 | 08:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This one should work if installed with the connector facing down. There appears to be a bunch of room for the connector. Adjustable isn't required on the 3rd gen TBI units as the ECM auto-zero's it. But being adjustable won't hurt anything, just get it in the 0.4V to 0.7V range.
RBob.
Old Nov 2, 2018 | 08:22 AM
Engine: 305 (LO3)
I don't think there is a whole lot of room for the vertical one. The connector also does not seem like it would reach without putting strain on the wires, if it reached at all.
Old Nov 2, 2018 | 11:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Very well may be. I did some checking on RockAuto concerning the two TPS units. As you mentioned the unit with the horizontal connector is correct for the '88 - '90 TB (note that many TBI trucks use this same one). While the unit with the vertical connector appears to be for the '85 - '89 TPI.
As @mecham84 posted, the Standard TH39 is what RockAuto lists for the '88 - '90 TBI.
RBob.
92RSZ
May 15, 2015 10:32 AM
85Iroc-Z
Mar 22, 2014 02:44 AM
junkcltr
Dec 4, 2005 10:15 AM
OutLaw305
Car Audio
Jan 25, 2004 02:57 PM
azcamaro
Jul 2, 2003 05:47 AM
